Thread: please help! how to remove rear speakers to put new ones!
Results 1 to 5 of 5
  1. #1 please help! how to remove rear speakers to put new ones!
    SE Level Member gpgtp99's Avatar
    Canada
    yesterday i change front speakers without no so much difficulty but the rears theres a lot of pins, and i dont want to break something so how do we remove it plz?
  2. #2 Re: please help! how to remove rear speakers to put new ones!
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    remove the rear seats and can get to them.
    3.4 pulley, 3" catless dp (ubend deleted), 3" exhaust split to 2.5 dynomax mufflers (no res), zzp plog, 4" spectre intake, alt rewire, under/overdrive pulleys, intense pcm, 3/4" zzp tb spacer, al 104's, 180* stat, msd coils/8.5mm wires, heatwrapped crossover, flipped db's, optima red top, sunpro st boost gauge: boosting 11lbs.
  3. #3 Re: please help! how to remove rear speakers to put new ones!
    Canada
    [QUOTE=a98gtp4u;283223]remove the rear seats and can get to them.[/Q
    to remove rear seats did its just clipsed or i have to remove screws?
  4. #4 Re: please help! how to remove rear speakers to put new ones!
    bolts/nuts
  5. #5 Re: please help! how to remove rear speakers to put new ones!
    Ohio
    bottom half just pull up in the front an they will pop out. there may be plastic tabs hanging out underneath the edge if they are there pull those an it will do the same thing. usually those are broken off though. next remove the 2 bolts holding in the upper half of the seat. then lift an pul towards u an the top half will come off. move both sections out of the way. lift up the decklid and your there.
    00 GTP demodded and forsale
  1. Rear speakers
    By Farmboy87 in forum Audio, Security & Visual Electronics
    Last Post: 07-19-2009, 10:09 AM
  2. how to remove the back speakers...
    By bb52190 in forum Off Topic Discussion
    Last Post: 10-09-2008, 07:47 PM
  3. Rear speakers cut out??
    By 91z in forum Audio, Security & Visual Electronics
    Last Post: 09-16-2008, 09:53 PM
  4. how to remove rear speakers ??
    By bayareagtp in forum Audio, Security & Visual Electronics
    Last Post: 07-03-2008, 10:52 AM
  5. no rear speakers
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2008, 06:44 PM
