Thread: Security system
Results 1 to 7 of 7
  1. #1 Security system
    SE Level Member musiknjoyr's Avatar
    Feb 2009
    decatur, al
    I just installed a scytek p-10 in my car and everything works great, EXCEPT, i cant get the parking light flash or headlight flash when u lock and unlock for anything i do not have a factory alarm. 2000 gp se, any help?
  2. #2 Re: Security system
    where did you hook up the white wire? did you test it before hooking it up?
    brandon
  3. #3 Re: Security system
    Feb 2009
    decatur, al
    yeah i put a multimeter on the white and their was an output. i tried connecting to the brown wire on the lightswitch first for the parking lights.nothing. then i tried the yellow for the headlights. again, nothing.
  4. #4 Re: Security system
    It should be the brown wire. Put a meter on it and turn the switch you should have 12volts, if not you;ve got something wrong, check fuses.
    brandon
  5. #5 Re: Security system
    Feb 2009
    decatur, al
    just tested both, both are putting out right on the money but no parking light flash AAAGHHHH
  6. #6 Re: Security system
    I would try adding the relay, it may not put out enough juice to kick them over. That'r thats the only thing i canthink of.
    brandon
  7. #7 Re: Security system
    SE Level Member docmafia's Avatar
    Mob Missouri
    It should be the brown wire at the head light switch, there might be some thing wrong or a feature turn off on your car alarm module.
  1. Wiring Diagram, Ignition/security system
    By boogsey in forum General Tech Discussion
    Last Post: 12-25-2008, 11:32 PM
  2. Stock Security System freaked out on me...
    By evol207girl in forum General Tech Discussion
    Last Post: 11-24-2008, 11:56 PM
  3. Security Relearn
    By 04CompG in forum General Tech Discussion
    Last Post: 09-12-2008, 05:25 PM
  4. Reroute security system flash to parking lights on 2004 grand prix
    By Jusplayn in forum Visual/Body Modifications
    Last Post: 05-16-2008, 12:59 AM
