Thread: How to get rid of trunk rattle.
Results 1 to 16 of 16
joshsGT How to get rid of trunk... 11-18-2009, 01:51 PM
matt5112 Re: How to get rid of trunk... 11-18-2009, 01:52 PM
joshsGT Re: How to get rid of trunk... 11-18-2009, 01:56 PM
KawaFord Re: How to get rid of trunk... 11-18-2009, 02:13 PM
ZR1Vette09 Re: How to get rid of trunk... 11-18-2009, 02:28 PM
GAFF Re: How to get rid of trunk... 11-18-2009, 02:38 PM
I800C0LLECT Re: How to get rid of trunk... 11-18-2009, 02:45 PM
matt5112 Re: How to get rid of trunk... 11-18-2009, 02:58 PM
GAFF Re: How to get rid of trunk... 11-18-2009, 10:19 PM
matt5112 Re: How to get rid of trunk... 11-19-2009, 08:39 AM
I800C0LLECT Re: How to get rid of trunk... 11-18-2009, 03:02 PM
matt5112 Re: How to get rid of trunk... 11-18-2009, 03:08 PM
joshsGT Re: How to get rid of trunk... 11-18-2009, 09:51 PM
1LoudGrandPrix Re: How to get rid of trunk... 11-19-2009, 01:16 AM
shawnz90 Re: How to get rid of trunk... 11-19-2009, 09:46 AM
matt5112 Re: How to get rid of trunk... 11-19-2009, 09:48 AM
  1. #1 How to get rid of trunk rattle.
    GT Level Member joshsGT's Avatar
    Nov 2009
    Marysville, MI
    hey everyone i have a 2002 grand prix gt sedan. i am putting my system in this weekend and was wondering if there is a way to get riid of the trunk rattle. my mom has the same car as me and her trunk rattles really badly with only 1 12" sub. if theres anyone who knows a successfll way then let me know pleaseee.
  2. #2 Re: How to get rid of trunk rattle.
    open the trunk pass through or remove the rear 6x9's.
    That pressure needs to get out somehow.
  3. #3 Re: How to get rid of trunk rattle.
    Nov 2009
    Marysville, MI
    ok, would that actually work or is that just a thought lol.
  4. #4 Re: How to get rid of trunk rattle.
    GXP Level Member
    Theworld
    That would not stop trunk rattle.
    If you're looking to go professional, you would need to pad the trunk.
  5. #5 Re: How to get rid of trunk rattle.
    MO
    be ready to spend alot... Dynamat. Stuff works though. Also look into their license plate cover that prevents rattle as well. No one likes hearing *buzzzzz buzz buz buzzzz*.
    <brandonl2000> LMAO D!!
  6. #6 Re: How to get rid of trunk rattle.
    Kansas
    One other thing you can do is adjust the trunk latch so that it holds the trunk more stiff. Like move the latch to where you really can hardly close the trunk
    SOLD 1999 GT Silvermist TS
  7. #7 Re: How to get rid of trunk rattle.
    Feb 2009
    Virginia
    When adding MLV(mass loaded vinyl) the idea is that you're adding physical mass to vibrating panels in order to change their characteristics. Adding this mass doesn't stop the vibration, it just changes the frequency it will vibrate.
    It doesn't have to be as expensive as others presume because they use a COVER EVERYTHING MENTALITY!!! Which is ridiculous. Don't confuse dampening with absorption or the attempt to block sound waves.
    Foam typically only dissipates sound above 8khz. Majority of the song information is between 100hz and 5000hz. Do you need the toher frequencies? OF COURSE!!, for roll off etc.
    Anyways, to get rid of rattle only cover 25% of the problem area to kill 90% of the rattle at the associated frequency. If you're trying to sound DEADEN/block sound, then you need to overlap MLV panels by a quarter inch when applied and create a wall of it. Then you dampen the sound with very thick and heavy foam. I believe closed cell is better in this application vs. open cell. When dealing with reflections...you want open cell.
    So there ya go...JUST COVER 25% of the problem area. You'll be good to go.
    11 is louder than 10!
  8. #8 Re: How to get rid of trunk rattle.
    Fvck guys, did anyone go out and look to see where the rattle was coming from? on mine it comes from the top lip, push that down, it stops.
    SO, you can either avoid pressure build up or add weather stripping so that part doesn't move.
    There isn't any science behind stopping a unique rattle. Find what is making the noise, and prevent it from doing that with the least amount of sh*t possible.
  9. #9 Re: How to get rid of trunk rattle.
    Kansas
    Thats what i was saying you adjust the latch to where it barely locks then it holds super tight
  10. #10 Re: How to get rid of trunk rattle.
    Quote Originally Posted by Gafford44 View Post
    That'd work if your rear trunk lip was the part that rattles. On my car, the front lip is the one that rattles, but only with bass heavy music like electro or DnB at full tilt.
  11. #11 Re: How to get rid of trunk rattle.
    Feb 2009
    Virginia
    Good point matt!! Our spoiler's have a NASTY TENDENCY FOR RATTLE!!
  12. #12 Re: How to get rid of trunk rattle.
    my spoiler actually doesn't rattle at all, I took it off to add washers and clean up under there. No rattle.
    Just the lip right by the bottom of the rear window.
  13. #13 Re: How to get rid of trunk rattle.
    Nov 2009
    Marysville, MI
    thanks everyone.
  14. #14 Re: How to get rid of trunk rattle.
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    my tail lights rattle like no other they literally move inside
  15. #15 Re: How to get rid of trunk rattle.
    SE Level Member shawnz90's Avatar
    Kenosha
    why just don't you face the subs to the front of the car you will gain more db and less rattle
  16. #16 Re: How to get rid of trunk rattle.
    If they're sealed you get the most SPL out of facing them backwards and at the rear lip of the trunk.
    This means having no trunk and putting weight behind your rear axle which can't help handling.
    See why subs in the trunk isn't practical?
  1. 2006 Bad Trunk Rattle
    By jjwitty in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2010, 02:13 AM
  2. rattle cans
    By NomeCrusher in forum Detailing Tips and Tricks
    Last Post: 08-14-2009, 04:27 PM
  3. Bad Trunk rattle
    By jjwitty in forum General Tech Discussion
    Last Post: 08-05-2009, 01:21 AM
  4. Rattle under hood
    By bronzegp in forum General Tech Discussion
    Last Post: 07-17-2009, 08:05 AM
  5. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
