Thread: Subs "freak out"
Results 1 to 15 of 15
  1. #1 Re: Subs "freak out"
    Hoffman/Schaumburg, IL
    Quote Originally Posted by s1795so2 View Post
    That is a likely possibility, but on a devil's advocate note: it would probably pop the main fuse from the strain it put on flow of current therfore increasing amperage.
    Usually an amps fuses on it are actually the worst case scenario on max amperage draw, but using so small of a wire would actually exceed that "worst case scenario."
    Just cause the wires are too small doesnt mean the fuse would blow, many,many times i've seen the fuse much bigger than the wire's capacity for current....
    But my cell phone does that thing on almost any radio, even the stock one gets feedback when I get a call
  2. #2 Re: Subs "freak out"
    GTP Level Member s1795so2's Avatar
    alhambra, Il
    Quote Originally Posted by 02BlueGT View Post
    yes I can see your point about people running a bigger fuse than the wire is rated for but the amps fuses would blow if it was pulling to much current as its own fuses can't support it and/or the wire would actually melt.
    Steven Oliver
    2004 GTP comp-g WS6. Gator and suede all around interior.
    Advanced MECP certified installer, custom upholsterer.
    <img src=http://i86.photobucket.com/albums/k87/s1795so2/random%20pics/manbike.jpg border=0 alt= />
  1. intermittent problems getting on "our" site?
    By GS-SC in forum Buick Regal
    Last Post: 01-03-2010, 12:03 AM
  2. What is K-factor "R115" on 4T65E TC?
    By agrazela in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-24-2008, 01:07 PM
  3. "Calibrated" A/F Gauge, are they worth it?
    By GeddyLee in forum Visual/Body Modifications
    Last Post: 02-12-2008, 03:16 PM
  4. "Mark All As Read" option?
    By VinnieGTP in forum Forum Bugs/Suggestions
    Last Post: 01-06-2008, 12:03 AM
  5. There should be a "Forum Bugs/Suggestions" section
    By syP in forum Forum Bugs/Suggestions
    Last Post: 12-13-2007, 07:48 PM
