Wrong, take out the rear seats. The bottom section can be pulled out by pulling on the plastic tabs, one on each side. Then undo the seat belts (I think its only the two center sections you need to remove, not the outer ones) and the two other large bolts there holding the rear section in. Once thats done, the upper carpeted piece will come out and you can finally unbolt your rear speakers.
