not necessarily. there could be a loose connection or something, but its hard to say where it is coming from...from what you describe it almost has to be either the head unit or the amp. If there are connections on that amp, I would unplug them and check them out make sure they aren't loose, thats the easiest thing to do. Other than that, you would just have to swap something out to see if it helps.
