Thread: Amp power question
Results 1 to 14 of 14
  1. #1 Amp power question
    SE Level Member isucyclones3's Avatar
    Jan 2009
    mason city
    I'm kind of new to car stereo and have a basic understanding but i easily get confused. I have 2 punch hx2's in a sealed box and I am powering them with a Kenwood KAC-9103d that puts out 900 rms x 1 at 2 ohms or 500 rms x 1 at 4 ohms. Since my subs are 4 ohms, are they each getting 500 rms or 250?
  2. #2 Re: Amp power question
    Are your subs dual 4 ohms? If so, you should wire your sub's voice coils in series and then the subs in parallel, this will net you 4 ohms (two ways to get 4 ohm load with these subs, both are fine) and deliver 250 watts to each sub. With those subs, you need a 1 ohm stable amp to get the most power out of the amp.
  3. #3 Re: Amp power question
    Jan 2009
    mason city
    Ya they are dual 4 ohm
  4. #4 Re: Amp power question
    Wire the coils of each sub in parallel and then the subs in parallel with each other. The manufacturer's website claims the amp is 1 ohm stable which means this will get you the most power out of your amp. This would be most likely around 500 watts a sub.
    If you wire them the way I mentioned in the other post you'd be at 250 watts a sub. I'd definately wire them the way I mentioned in this post seeing as the manufacturer claims 500 watts RMS on the 10' and 12" versions.
  5. #5 Re: Amp power question
    Jan 2009
    mason city
    When I bought the subs this past weekend, they were already in the box and today I popped them out to see how they were wired and the box has a board between the two subs, so it is like they are each in their own box. So i cant wire them together
  6. #6 Re: Amp power question
    Yeah you can, just run the wire outside of the box. If everythings in parallel, run speaker wire to each sub and at the amp connect both positives to the positive and same with the negative.
  7. #7 Re: Amp power question
    Jan 2009
    mason city
    Ya i guess i didnt think about that haha. So do as it says in wiring option 1?
    Rockford Fosgate® - Woofer WiringWizard
  8. #8 Re: Amp power question
    Yup, that'd be the one.
  9. #9 Re: Amp power question
    Jan 2009
    mason city
    Ok. And on my amp I have 2 positive and 2 negative speaker terminals, and you said to put both positive speaker wires into 1 positive and to do the same with the negative? Correct?
  10. #10 Re: Amp power question
    Yeah, check on the amp, it should tell you where you hook up the positive and negative for using it bridged.
  11. #11 Re: Amp power question
    Jan 2009
    mason city
    Ok thank you very much. I will try to get everything worked out tomorrow after school.
  12. #12 Re: Amp power question
    Not a problem, lemme know how it goes.
  13. #13 Re: Amp power question
    Jan 2009
    mason city
    So i got everything wired right and they are working, always a good sign but when i connected my speaker wire to my amp, it didnt say where to put them if i was bridging them so does it matter what positive and negative i used?
  14. #14 Re: Amp power question
    I'd wire the positive wire to the most outside positve terminal and the negative wire to the most inner negative terminal.
  1. V-Power Gas Question?
    By beejay76 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-04-2009, 12:10 PM
  2. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
  3. How much power do i have
    By gp3800t in forum General Tech Discussion
    Last Post: 03-18-2009, 02:39 PM
  4. power steering pump question
    By kjohnson in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-17-2009, 10:30 PM
  5. power window slash electrical question
    By SlowPurpleGTP in forum General Tech Discussion
    Last Post: 06-22-2008, 09:25 PM
