Thread: Uncontrolable honking
Results 1 to 12 of 12
  1. #1 Uncontrolable honking
    Serena, IL
    So yesterday, i was driving behind a cop, and all of a sudden the horn on my GTP just started to honk. It wasn't like the alarm was going off, just random bursts of honking. Any ideas?
  2. #2 Re: Uncontrolable honking
    my car did this too. i couldnt get it to stop so i pulled the horn fuse and never was able to use it again. i assumed it was grounding out somewhere and allowing the horn to just blare on its own.
  3. #3 Re: Uncontrolable honking
    Most likely a broken piece in the steering wheel, right behind the airbag.
  4. #4 Re: Uncontrolable honking
    Apr 2009
    Wausau, Wisconsin
    Did you get pulled over?
    If so I am sorry but that's funny!
  5. #5 Re: Uncontrolable honking
    Ocala, FL
    If I told you I read your post without laughing, I'd be a liar.. Hah... Anything come of it though? And sorry I have no idea on what it would be!
  6. #6 Re: Uncontrolable honking
    Serena, IL
    Yes, i did get pulled over. Luckily the cop was a good sport and i explained the situation. I took the car into the dealership yesterday, and they just couldn't understand what happened, so im probably just going to disconnect it if it gets worse.
  7. #7 Re: Uncontrolable honking
    Minnesota
    I've had my horn honk unexplained about 3 times in 3 years. I'll just be driving down the road and it will honk and scare the crap out of me. I was wondering what would cause this too
  8. #8 Re: Uncontrolable honking
    SE Level Member Piggy's Avatar
    Cincinnati, Ohio
    take your hand off the horn... der
  9. #9 Re: Uncontrolable honking
    GTP Level Member tazyboy28's Avatar
    home town
    Quote Originally Posted by xringshooter7 View Post
    isnt it obvious ur a pig hater . . . it happens in uncontrolable conditions when u least expect it. Followed by racial slurs and associated with the middle appendage of the left hand. The medical term is called A$$hole.... very normal
    specs:2007 GP GT, wizair intake, ZZP headers, 3inch high flow cat downpipe. SLP power flo exhaust
  10. #10 Re: Uncontrolable honking
    Feb 2010
    Rice
    ha ya'll act like your hard butts, but that happened to me it would only do it if i had my tilt wheel all the way down, move it up a notch and it would stop, so i just dont move it all the way down anymore.
  11. #11 Re: Uncontrolable honking
    MO
    did anyone else think "little miss sunshine" when they read this?
    <brandonl2000> LMAO D!!
  12. #12 Re: Uncontrolable honking
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    ^^lol funny shyt, but sounds like a wires getn pinched had these problems at my shop on gm cars, after awhile they get pinched or the plastic peice with the spring brakes and short to ground easy fix if u have the colum/steering wheel puller tools to take it apart and inspect the wires (u could even rent tool at autozone)
