Thread: Battery Dead.. Perhaps from the AMP?
Results 1 to 16 of 16
  1. #1 Battery Dead.. Perhaps from the AMP?
    SE Level Member Supercharged03GTP's Avatar
    Hudson, MA
    I have an 03 GTP and I have subs and amp hooked up as well... I didn't hook the power wire for the amp to the + Terminal of the battery because it doesn't have the posts ontop of the battery, and only has side posts, so I hooked up the power wire to the big black fuse box that has the red plastic + sign on it and behind that plastic piece there is a bolt where I hooked the amp power wire to, to that fuse box.. Could that be the reason why my battery is completley dead.. It's a brand new battery and only had the battery for a max of 2 weeks.. Please help.. Thank you to those that reply.
  2. #2 Re: Battery Dead.. Perhaps from the AMP?
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    hook it up to the side post if you need to get a extender for it
    make sure your amp isn't set to be on all the time
  3. #3 Re: Battery Dead.. Perhaps from the AMP?
    Hudson, MA
    Quote Originally Posted by TurboTrav View Post
    How do I check to make sure the amp isn't all on the time? Besides looking at the amp to see if it's still running even after the fact the car is off, what else do I look for.. Is it possible that the remote wire is hooked up wrong causing the draw??
  4. #4 Re: Battery Dead.. Perhaps from the AMP?
    Charles City, IA
    Hooking it up where you did should work fine. That is where the battery cable goes.
    SMGPFC Two Nipple General
  5. #5 Re: Battery Dead.. Perhaps from the AMP?
    Cedar Rapids, IA
    unless you pull to much power then run the risk of a fire
  6. #6 Re: Battery Dead.. Perhaps from the AMP?
    Dec 2008
    chicago,illinois
    Quote Originally Posted by Supercharged03GTP View Post
    I have my set up hooked up the same way never had a problem
    going low on 20"
  7. #7 Re: Battery Dead.. Perhaps from the AMP?
    CT
    do you have your AMP set to be running at all times or just when the car has ignition power?
  8. #8 Re: Battery Dead.. Perhaps from the AMP?
    Cedar Rapids, IA
    when you take the key out and open the door the amp should shut off
  9. #9 Re: Battery Dead.. Perhaps from the AMP?
    Hudson, MA
    Yes it shuts off.. I even checked to see if the light on the amp shuts off... I just bought a new battery and it's working fine for now, we'll have to see what happens.. I even went as far as buying a volt meter gauge to put on an A-pillar just haven't installed it yet, that will be my next mission, and that way I'll be able to monitor the voltage and keep a closer eye on it. I also checked behind the kenwood head unit and check the wiring, and it appears to be fine.. I hooked up the remote wire from the amp to the back of the head unit, along with some pink wire from the stock harness to the remote wire behind the head unit because the Bose speakers wont work if it's not connected to it, then I also hooked up the blue wire that said Constant P to those two as well and my amp works that way, and yes it shuts off as well after turning the key to the off position and opening the door, so I dont know what it could of been that killed my battery.. Also my amp is an 800 watt kenwood amp, with two 12inch Kicker comp subs... Any other suggestions? Thanks again.
  10. #10 Re: Battery Dead.. Perhaps from the AMP?
    SE Level Member lorenzojay's Avatar
    Roseville Mi
    Im running a California ap1060 1000 watt amp and 2 12 inch kicker comp subs and I havent had any problems, My power is connected to the Fuse box terminal as well. What do you think of thos Kicker comp subs Super?
  11. #11 Re: Battery Dead.. Perhaps from the AMP?
    Hudson, MA
    Quote Originally Posted by lorenzojay View Post
    I think those kicker comps are the awesome. They bump pretty well.. I'm happy with them.
    Maybe my battery drained because I had my ipod charging in my car with the car off while I was at work, and had it charge atleast a good half hour to an hour so maybe after that, the battery was on it's way out perhaps
  12. #12 Re: Battery Dead.. Perhaps from the AMP?
    Roseville Mi
    an I pod wont drain your battery, I leave my radar dector on all night sometimes and car starts fine, I wish there was a way to make the power outlets turn on and off with the ignition. In my 07 nitro you can move a fuse to have it always on or turn on and off with the car. Oh and that amp I talked about in my prev post may say its a 1000 watts but in reality to the spec sheet its a 4 channel running 80x4 or 250 bridged so Im just running 80x2 and Im not even pulling anough power to make the headlights blink.lol
  13. #13 Re: Battery Dead.. Perhaps from the AMP?
    A new battery on its way out? You should have had it warrantied.. Free replacement on the spot if it died in two weeks.
    The question is, are your amps turned on by a 12V source or signal sensing via RCA/hi-level input?
    If its the former, choose a new line or run an extension off of the line for your head unit. If its auto sensing, faulty amp unless it has an adjustable sensitivity (highly unlikely).
    Also, if your headunit has a demo mode, that may kill it.
    These cars have a 10 min auto shutoff on the lights so you can't do too much damage to the battery.
    How so? All of the fuses would blow before that could happen unless you didn't fuse your setup properly. The alternator wire is a fusible link which automatically prevents that source of overcurrent and the line you ran to your amps should be fused (for the total combined amperage of your fuses plus a safety net of say 10%) as close as possible to the power source.
    If you really pull too much power, you run the risk of destroying your alt because you'd be using it to the point where it must provide lower voltage to provide the same level of current. On top of that, it'd pull power from your battery. If you really went overboard you could in theory stop your car because it wouldn't have enough power for the ignition or fuel pump. But if its all setup properly then there would be no fires.
  14. #14 Re: Battery Dead.. Perhaps from the AMP?
    Hudson, MA
    I really don't think it's my amp that's killing the car.. I took a volt meter to the battery with car off it and it was running 12.7 volts and then some, with car running it was up around 13.8 to 14.2 volts so everything is checking out fine... I'm now wondering if possibly it was a defective battery?? That's always possible right?
  15. #15 Re: Battery Dead.. Perhaps from the AMP?
    Cedar Rapids, IA
    i've dropped the rpms pretty low a couple times, low enough to make me hit the gas
  16. #16 Re: Battery Dead.. Perhaps from the AMP?
    Roseville Mi
    yeah its always a possibility
  1. battery help!
    By DDPeppa in forum General Tech Discussion
    Last Post: 08-23-2009, 11:49 PM
  2. battery dying
    By jaketrey32 in forum General Tech Discussion
    Last Post: 07-29-2009, 05:10 PM
  3. okay, I took the battery out of my '96 GP
    By karkev in forum General Tech Discussion
    Last Post: 06-17-2009, 09:21 PM
  4. Battery Light
    By awq134 in forum Introductions/Noob Questions
    Last Post: 04-29-2009, 12:17 PM
  5. Small battery
    By Arkanzan Wheeler in forum General Tech Discussion
    Last Post: 05-24-2008, 10:33 PM
