Quote Originally Posted by speedemongtp View Post
in the manual there is also a way to turn down the sensitivity its a series of pushing the lock an unlock buttons on the remote. not too bad i did it once
How is it that i always neglect to find the obvious simple solution... THANKS!!
Procedure to reduce alarm sensitivity:
-Shut all doors.
-Put key in ignition, do not turn it.
-Remove the mall PGM fuse in the glove.
-Turn the key one click toward you (it cant go any further toward you, i beleive this is called accessory mode)
-Turn your parking lights on. (turn the dile one click clockwise).
-Listen to the chimes (should be 4 for mode 4: normal sensitivity mode)
-Turn parking lights off
-Turn them back on (now you should hear one chime for mode 1: Reduced sensitivity mode){if you do not hear one chime cycle the lights from on to off till you do}
- Turn parking lights off
-Put the fuse back in
-Cycle the key to off.
-Party
