Thread: 12volt switched source?
Results 1 to 9 of 9
  1. #1 Re: 12volt switched source?
    May 2008
    The wiring harness you buy to plug into your factory harness tells you everything you need to know. If it is telling you that you have to get the 12v switch from someplace because it isnt in the factory harness then follow the directions.
    Newer cars have DATA wires to control things. Basicly computer wire that communicate to another computer.
    To get yourself another 12v switched suppy go to igntion switch or to BCM for the ignition. The power ant. is not suppose to be used for anything but to tie into your factory harness for any type of powered antenna. As for any monsoon systems with amps as long as you have your remote output lead going into your remote output lead in the factory harness plugin you will power up your factory amp.
    You hook it up incorrectly you can do serious damage to the car. Chances of a dealer fixing it under warranty is VERY slim then.
    So FOLLOW the directions very closely or pay to have it done.
  2. #2 Re: 12volt switched source?
    SE Level Member nyydmb12's Avatar
    New York
    yea i just paid my friends uncle to do it...he cut into the ignition ...I never have the right tools
    2004 grand prix gtp
  1. Antifreeze in Oil - How to determine the source.
    By warrenz in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2009, 10:10 AM
  2. Source for stock front sway bar?
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2009, 07:44 AM
  3. Most likely source for coolant leak?
    By nlinesk8s in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2009, 08:09 AM
