Thread: Interior switch leds
Results 1 to 11 of 11
  1. #1 Interior switch leds
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    so i am going to be switching all the red to blue and have sent a lot of time trying to find out what i need to use for the switches and have had no luck. so my question is will these work for everything?
    Lot of 25 X 3mm Blue LED Lamps 15000mcd Free Resistors - eBay (item 270430541492 end time Jul-23-09 18:27:12 PDT)
  2. #2 Re: Interior switch leds
    London Ont, Canada
    Nice item - im working on mine soon as i get my body work done. I will be following to see how ya do - door switches are the easiest. Im still working out HVAC/Gear/Speedo cluster.
  3. #3 Re: Interior switch leds
    St. Louis
    i feel like 15,000 mcd might be a little much should i go with something lower like 5,000 or 3,000 ?
  4. #4 Re: Interior switch leds
    London Ont, Canada
    this is what i was going to use http://ledshoppe.com/Product/led/LE4003.htm
    had some heads up from othter members on here.
  5. #5 Re: Interior switch leds
    St. Louis
    same things i ended up going with except i paid $3.00 for them on ebay, but i only got 50 of them. I also am thinking that i might do a write-up on the process of changing all the interior lights (switches, DIC, Radio, etc...)
  6. #6 Re: Interior switch leds
    London Ont, Canada
    look first, there are write ups, i am curious tho how you do the HVAC and dash cluster. ive already got my door switches underway. but thoes other 2 i dunno about, problem i found is the HVAC knobs are red inside making it harder to change thoes no matter the colour of LED...
  7. #7 Re: Interior switch leds
    St. Louis
    wonder if you can take finger nail polish to them, like when removing the orange from the cluster needles?
  8. #8 Re: Interior switch leds
    Apr 2009
    Wausau, Wisconsin
    Just brain storming here but I know from having my old Grand Am the Alero's had blue plastic under the rubber coating so if they fit that would work. I do not know if they fit though.
    Quote Originally Posted by stlmo_gtp View Post
    Tell me more about removing the orange from the cluster needles I am interested!
  9. #9 Re: Interior switch leds
    London Ont, Canada
    I'm hitting up the junk yard this weekend. I will look around
  10. #10 Re: Interior switch leds
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    ^^^ has a great idea. you can tamper with another dash cluster, hvac from a junkyard and experiment with that, til u get a good solution on getting the orange tint to come off. Saving u any mistake on ur only dash.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  11. #11 Re: Interior switch leds
    London Ont, Canada
    thats what ive been doing, ive got about 4 gear shifter inserts to try, so far nailpolish remove is good but too good lol.. ive got extra knobs ive been tyring to dremel into submition
    sure you spend a few bucks on waste, but sure a hell better then effing up my stuff on my car, after all its my daily driver i need a tried and true method before i do anything
  1. Where is A/C pressure switch?
    By PCweber in forum General Tech Discussion
    Last Post: 03-29-2009, 07:13 PM
  2. TC switch
    By pontiac667 in forum General Tech Discussion
    Last Post: 03-01-2009, 12:31 PM
  3. Need a thermal switch
    Last Post: 06-27-2008, 01:30 PM
  4. Brighter LEDs in angel eyes (Projectors)
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 06-21-2008, 12:10 PM
  5. Changing LEDs in your angel eyes [*]
    By Preotic in forum How To Write-Ups/Tech Tips
    Last Post: 04-11-2008, 11:05 PM
