Thread: 2006 Bad Trunk Rattle
Results 1 to 20 of 20
  1. #1 Re: 2006 Bad Trunk Rattle
    Indy
    i was able to take the spoiler completely off, remove the factory sound deadening material, lined the whole spoiler that made contact with weather stripping. also took the brake light out of the spoiler and lined that also. the brake light was a huge part of the rattle. however, today i found out that my so-called 1000 watt amp was no where close to pushin that much. there are 2 25 amp fuses in the amp and that is a tell-tale sign i guess. so now i'm lookin for a true 1000 watt amp. are the fuses the only way to really tell if it truly pushes 1000? but now i'm wonderin if maybe the guy that had the amp before me may have accidentally put the wrong fuse in the amp. would that hurt performance? and would the wrong fuse even fit? kinda new to all of this.
  2. #2 Re: 2006 Bad Trunk Rattle
    Feb 2009
    Virginia
    Its a good sign of what it'll do.
    If its class D maximum efficiency is around 88% which means 88% of the power it draws, it turns into output. Most class A/B amps are around 50%.
    SSA Shop - Sundown Audio SAZ-1000D amplifier
    Heres a real 1000 watt amp. Price isn't the best in the world, but apparently the quality is okay.
    They're made in Korea. Quality is pretty decent. Great value for the money...not a diamond in the rough but probably top of it's class in that price range.
  1. Rattle under hood
    By bronzegp in forum General Tech Discussion
    Last Post: 07-17-2009, 08:05 AM
  2. Can't figure out this rattle!!!!
    By Gooch in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2009, 11:35 AM
  3. rattle on accelleration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2008, 02:31 PM
  4. Rattle Trap....
    By SLO-6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-04-2008, 07:11 PM
  5. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
