Thread: Keyless Entry
Results 1 to 7 of 7
  1. #1 Keyless Entry
    Apr 2012
    Louisiana
    Where can I purchase a replacement chip for my 2006 Gxp keyless entry remote? I already have the case & buttons but need the chip on inside.
  2. #2 Re: Keyless Entry
    Yoga city
    ebay man is gonna be the cheapest
  3. #3 Re: Keyless Entry
    Apr 2012
    Louisiana
    Thanks for responding
  4. #4 Re: Keyless Entry
    Springfield Missouri
    Yeah Definately ebay if you can find a dealership there like 50bucks which is outragous but its a dealership so there not trying to help anyone out. Just ordered a remote yesturday for 20 bucks on ebay brand new. Good Luck!
  5. #5 Re: Keyless Entry
    Apr 2012
    Louisiana
    Quote Originally Posted by jakobkay View Post
    >>>>>>><<<<<<< Thanks. Must it be programmed by the dealer or can it be done by yourself? Or at an audio/specialty shop?
  6. #6 Re: Keyless Entry
    Yoga city
    04+ models have to be programmed via dealer,
  7. #7 Re: Keyless Entry
    Jun 2012
    Mount Airy, NC
    I just got a FOB and following are the programming instructions. Problem is mine worked initially but now the lock button will not operate. Everything else does so I am going to try to re-program.
    Here is the programming for you to try again, let me know how it goes.
    Obtain all remote transmitters for this vehicle.
    1. Remove key from ignition.
    2. Remove the MALL PGM/BCM PGM fuse from fuse box.
    3. Close all doors.
    4. Turn ignition switch to ACC. (ACC is turning the key back toward you).
    5. Within 1 second turn the ignition to OFF then back to ACC. (OFF is the position where you can remove your key)
    6. Open then close the drivers door.
    7. An acoustic sound will be heard after closing the door indicating the vehicle is in programming mode.
    8. Hold the LOCK and UNLOCK buttons on the remote for about 15 seconds until two chimes are heard.
    9. Repeat step 8 for any additional remotes including working ones.
    10. Remove key from ignition and replace MALL PGM fuse.
  1. fix my keyless entry!
    By foursixer in forum Audio, Security & Visual Electronics
    Last Post: 10-18-2011, 07:20 PM
  2. keyless entry help
    By Doug 97 gtp in forum Audio, Security & Visual Electronics
    Last Post: 10-17-2011, 08:25 PM
  3. Keyless entry
    By zildjian102 in forum Audio, Security & Visual Electronics
    Last Post: 01-24-2011, 09:14 AM
  4. 94 keyless entry
    By eeltam in forum General Tech Discussion
    Last Post: 01-05-2011, 05:49 PM
  5. No keyless entry!
    By tmackster in forum The Rant Forum
    Last Post: 07-22-2009, 02:44 PM
