either that or take a wire coat hanger,(straightened) bend over one end- leave enough of a flat loop to put the wire in later, and secure loop w/ electrical tape. push this end through the flex peice, into the door. slip the wires through the flat loop at the end, and pull it back through. --- if needed/desired you can tape the wires to the hanger, but most times this is not needed
