How thinks it's a good idea to put subwoofers in my car. The only reason I don't want to is because my last car burned to the ground because of the stearo. If I get a new 1 all I'm going to have is 1 12 inch dd audio 9500.
fuses are your friend, they will stop those lil mishaps were cars start on fire because of stereos. Also drill a hole threw the fire wall for the power wire going threw door jams is all kinds of bad esspesially if you dont use a fuse.
I had 2 250 amp fuses 1 going to the battery under the hood and another going to the battery in the trunk. The thing that caused the fire was a freak spark from 1 of the amps
yea put a sytem in i have a 15" 9500 in mine nd i love havin a bass. nd u wount need to drill a hole in ur firewall their is an unesed ruuber plug below the stering columb that u just need to poke a hole through to run ur wires (atleast their was in my 98 gtp coupe)..i did that than ran them under the plastic around the door nd under the carpert so u dont see n e wires
DDAudio Digital Designs Speakers Made in the USA - DD9500g
Do u have a 9500 dd or mtx and what amp do u run I had a earthquake and it was 2000 rms
do it. i run a single infinity 12 in an it kicks some major @$$. Theres a grommet in the passenger side floor thats alot easier to run through than the drivers side one cause it uses up less wire cause u dont have to run it all the way across to the drivers side. Just pull back the carpet an its right there plain as day. poke a hole in it, fish ur wire, an ur good to go.
i run 2 MTXx 12" terminators in the terminator box with a 1000 watt amp i cant go wrong ha. and yeah drill or poke a hole threw the rubber port on the passenger side floorboard in the firewall. just use a inline fuse with a fuse holder from like rosgate or that ghetto walmart shohshe or w.e company they all do the same thing ha.WOULD U HAVE A FIRE???
my trunk is gutted out![]()
ok i just dont want this car to end uo like the last, in a big ball if fire at walmart. and by the way i had about 8000 watts in the trunk at the time and maybe $6000 worth of **** that all went up in flames, and i had it instaled by a car audio shop. the only good thing that i got out of the fire was my GTP lol
Moved to correct section.
install the stuff yourself not some kid getting paid low wages that dosn't care if the car blows or not
yes do it. everyone loves audio!!!
