Thread: HID Help
Results 1 to 20 of 32
  1. #1 HID Help
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    thnx for vail, I have this site for HID's HID Conversion Kits - Single Beam Model VVME.COM LLC Your Best HID KIT Supplier
    I want to do something crazy, order 3 kits of HID's for lows, highs, and fogs. I wanted to know what would be the bad effect for doing this? like any heat issues? wiring poblems? also looking into the 10000k, which one would match the fogs? the same 10000K ?
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #2 Re: HID Help
    Banned - Busted For Scamming
    Feb 2009
    the bad thing? expensive. it can and has been done though no problem
  3. #3 Re: HID Help
    Aug 2008
    Fayetteville, NC
    bad thing, expensive...not an issue
  4. #4 Re: HID Help
    Feb 2009
    go for it then, one bulb to a ballast as you already know. youre gonna blind people with that setup
  5. #5 Re: HID Help
    Aug 2008
    Fayetteville, NC
    i get blinded all the time, i'm used to it...I wonder if brands make a differnce
  6. #6 Re: HID Help
    Jul 2008
    Tampa, FL
    10k is going to be very blue...and also, remember not to flash your brights when you get them because they take a sec to warm up when you turn them on, and you will burn out the bulb if you turn on an already warm bulb (sounds like it would be worse to turn on a cold one, but its not)...
    ...from my experience, brands do not matter...
    ...as far as the heat goes, i wouldn't put all the ballasts near each other, so good luck finding enough places for them to all fit. i'm not saying it can't be done, but good luck...lol
  7. #7 Re: HID Help
    Aug 2008
    Fayetteville, NC
    i'm not sure i understand what u mean by flashing brights...u mean dont use the brights? I THINK the lows are on when the highs are, cant remember. I been youtubin', i think the 10k will get an easy ticket, still watching vids on 8k. where did u put ur ballasts?
  8. #8 Re: HID Help
    Jul 2008
    Tampa, FL
    like, don't repeatedly flash them, like, if you are getting someone's attention. lows are on when highs are...you are correct. i screwed the ballast to the frame, you will find a spot, its easy enough...
  9. #9 Re: HID Help
    Aug 2008
    Fayetteville, NC
    wow the frame? lol...when u cut ur car on, are ur lights dim then gradually get brighter? if so, what was the company u bought from? apparently some are cheap knock-offs and dont dradually get brighter...
    such as this as soon as he cuts the lights on
  10. #10 Re: HID Help
    Jul 2008
    Tampa, FL
    yeah, they have like a 2 second warm up period because of the igniter. i got em on ebay from a store called endlesscarparts.
    mine get really bright pretty quick tho...i love em. i could video turning them on tonight and post it on youtube if that would help you...
  11. #11 Re: HID Help
    Aug 2008
    Fayetteville, NC
    I dont want to bother u with uploading and camming, all that great stuff, it is alot of work...but if you wouldn't mind it'll be another project to do on R&R lol
  12. #12 Re: HID Help
    Aug 2008
    Fayetteville, NC
    Find Stores
    More Stores search options
    0 Stores found with items matching endlesscarparts
  13. #13 Re: HID Help
    Jul 2008
    Tampa, FL
    eBay My World - endlesscarparts
    i couldn't find em in the search either...how shady...lol
  14. #14 Re: HID Help
    Aug 2008
    Fayetteville, NC
    k thnx lol...will check it out tmrw, its 1:30am here
  15. #15 Re: HID Help
    Jul 2008
    Tampa, FL
    check it...
    the first one is in my parking lot, so you can't really see it too well, so i went to a dark parking lot nearby and did it again...also, i'm noticing now that my beams are aimed pretty low...lol. i might need to aim them a little higher...also, since they were done on a digital camera, they don't look NEARLY as bright as they really are...
    YouTube - 8k HID turn on
    YouTube - HID turning on
  16. #16 Re: HID Help
    Aug 2008
    Fayetteville, NC
    thanks alot man, you should posts those vids in your "new HID's and Subs" thread so other people can see Any Idea on how the bright lights would look? I'm thinking like awesomely godness haha... and when i put my silvanya bulbs in, I had no issue with headlight being aimed low or high. also being aimed low might help from blinding the sheet out of some poor teen
  17. #17 Re: HID Help
    Jul 2008
    Tampa, FL
    Quote Originally Posted by offroadfury6 View Post
    no problem, the brights would probably look like if you harnessed the energy of the sun into a headlight, lol. i think my headlights were just aimed low before i got my HID's. it has nothing to do with the new bulbs. i think you just turn a few screws to change it. one for up/down, and one for left/right. yeah, you should def. aim yours low if you're doing a 3 light setup for the sake of granny and all the others out there that don't like extremely high light output in their retina's...
  18. #18 Re: HID Help
    Aug 2008
    Fayetteville, NC
    yeah I'm going to go with a 9005 setup first ( brights only ) and see how i like it, my low beams are already great
  19. #19 Re: HID Help
    Aug 2008
    Fayetteville, NC
    well F it, i think i'm just gonna order the 3 sets of HID kits, how hard is it to find space? as far as like mounting? cause u said something in a earlier post about goodluck
  20. #20 Re: HID Help
    Jul 2008
    Tampa, FL
    may just require some drilling of some holes...there is plenty of space to do it i'm sure. i was just saying good luck because you wont be able to find a place to put 3 ballasts by using local screws/grounds for wires/etc...
hid
