Thread: preamp help
Results 1 to 5 of 5
  1. #1 Re: preamp help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Quote Originally Posted by kjohnson View Post
    when i had it set up in my last car it worked fine but i thought that if you had a stronger signal that it was better for the amp and you would be getting a better sound quality. or is that not true
    It's not better for the amp. It's not worse, either, it just doesn't matter to the amp as long as it's set up for the same levels that you're giving it. The SQ can be better; with a larger amplitude input, the effects of any interference you might be getting would be less, lowering the noise floor. If you don't have interference issues, it's not going to matter at all.
    2001 Buick Regal LS - Almost Stock
  2. #2 Re: preamp help
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    ok sounds good thanks for the help ill just leave it be and save the money
    thanks again for the help
    silver 2003 Grand Prix GT List is on it's way to be updated
