Thread: preamp help
Results 1 to 5 of 5
  1. #1 preamp help
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    im trying to find a pre amp booster for my car since my alpine cda-9856 only has 2 volts of out put. i know that it will work just to leave it the way that it is now but i think that i fi was running in the 6 volt range my amp wouldnt have to work quite as hard. anyone know where i can find one im having alot of trouble finding one
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: preamp help
    GTP Level Member Scimmia's Avatar
    QCA, IA
    The voltage gain stage in the amp doesn't work hard anyway, I wouldn't worry about it unless you're getting interference issues or your amp isn't set up to deal with 2V input.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: preamp help
    Nov 2008
    when i had it set up in my last car it worked fine but i thought that if you had a stronger signal that it was better for the amp and you would be getting a better sound quality. or is that not true
  4. #4 Re: preamp help
    QCA, IA
    Quote Originally Posted by kjohnson View Post
    It's not better for the amp. It's not worse, either, it just doesn't matter to the amp as long as it's set up for the same levels that you're giving it. The SQ can be better; with a larger amplitude input, the effects of any interference you might be getting would be less, lowering the noise floor. If you don't have interference issues, it's not going to matter at all.
  5. #5 Re: preamp help
    Nov 2008
    ok sounds good thanks for the help ill just leave it be and save the money
    thanks again for the help
