Thread: want to build a real custom box.
Results 1 to 11 of 11
  1. #1 want to build a real custom box.
    Jul 2008
    Poteau Oklahoma
    does anybody know where I can find the rings made of mdf?
    I want to build a fiberglass box and making my own of plywood to me is useless.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  2. #2 Re: want to build a real custom box.
    Jul 2008
    Poteau Oklahoma
    really???? nobody???? nothing!!!
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  3. #3 Re: want to build a real custom box.
    Apr 2009
    Wausau, Wisconsin
    My guess is to cut your own? I never knew you could buy them already like that. If you disagree with me head to google.com, I hear that have lots of stuff.
  4. #4 Re: want to build a real custom box.
    Ohio
    No idea i would try a craft store or hardware store.
    00 GTP demodded and forsale
  5. #5 Re: want to build a real custom box.
    St. Louis Mo.
    James Shafer
    St. Louis MO
  6. #6 Re: want to build a real custom box.
    Jul 2008
    Poteau Oklahoma
    Geddy you are the man!
    I looked for a couple of weeks, apperantly just not in the right places.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  7. #7 Re: want to build a real custom box.
    St. Louis Mo.
    Glad I could help out Can't wait to see your design. If you need blue prints or instructions, I have some saved from various sites that help you construct your own box. You have to remember every subwoofer is different so you need to make the sub box fit the needs of your subwoofer to obtain maximum performance.
    James Shafer
    St. Louis MO
  8. #8 Re: want to build a real custom box.
    Springfield VA
    You need to find the T/S specs for the woofer[s] your using, and then custom tailor the box to those specs, and if youve never designed/built a box i wouldnt touch fiberglass. standard MDF is quite the challenge, but if you have any questions shoot me a PM, ive been doing this **** for about 6 years, and just finished the new box for the GP [although i learned an important lesson, then beer does mess up my lines when cutting]
    Quote Originally Posted by UR LOSN View Post
    all depends on how fast/broke you want to go.
  9. #9 Re: want to build a real custom box.
    Jul 2008
    Poteau Oklahoma
    I would galdly take any prints and specs you all have.
    my plan is to put two 8 where the rear console folds down and a 15 in the trunk.
    Luda why do you say fiberglass is bad?
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  10. #10 Re: want to build a real custom box.
    GT Level Member jasonball's Avatar
    Nov 2008
    ft. mitchell
    fiberglass is bad for your first custom box. becuase think with fiberglass your are working with curve and contours that take up and take away air space compared to a mdf box which is square. so fiberglass is tough to get the specs down right.
    This box took about 3 weeks
  11. #11 Re: want to build a real custom box.
    Springfield VA
    its messy, time consuming, and a pain to work with the first few times. if you REALLy want to fiberglass the enclosure into the car i recomend a hybrid design. build the actual enclosure out of MDF, then fiberglass it into the car.
    if you give me the subwoofer specs [Thiele/small parameters] of your sub and amp i could tell you what size enclosure you need, and whether you should go ported/vented or sealed
  1. Is this for real?
    By MARKS99 in forum PCM Tuning
    Last Post: 03-30-2009, 06:31 PM
  2. did anyone on here get a real kill?
    By 98gtp1000 in forum Track Sessions and Kills
    Last Post: 03-07-2009, 10:31 PM
  3. is this for real!!!!?
    By justwhisen in forum Off Topic Discussion
    Last Post: 02-25-2009, 01:47 PM
  4. G8 ST ??? yeah its real!
    Last Post: 11-27-2008, 01:40 PM
  5. First REAL car 99 GTP
    By GTPJOE90 in forum Introductions/Noob Questions
    Last Post: 06-20-2008, 12:19 AM
