Thread: Steering Wheel Lights Out
Results 1 to 16 of 16
  1. #1 Steering Wheel Lights Out
    Wichita
    The audio control buttons on the LH side of my steering wheel went dark. Guess I have a light out. Best way to go about fixing that?
  2. #2 Re: Steering Wheel Lights Out
    Dec 2008
    Lawndale, CA
    I have the write up bookmarked on my home computer. I will post it when I get home. You have to open the switch and solder in a replacement bulb. You can get the replacement bulb at Radio shack. Or you can go on ZZP's site and look for the LED replacement controls.
    ZZ Performance
  3. #3 Re: Steering Wheel Lights Out
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    I found a write up on ClubGP (can I say that here?)
    ClubGP:
    I bought a set off a member here, but went to put it in and that one is burned out also. Thinking of stopping by radio shack and try to get a replacement..
    Good Luck...
  4. #4 Re: Steering Wheel Lights Out
    Dec 2008
    Lawndale, CA
  5. #5 Re: Steering Wheel Lights Out
    Banned - Busted For Scamming
    Feb 2009
    easy to do, done it to both mine, not that hard.
  6. #6 Re: Steering Wheel Lights Out
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    ha, easy said, try replacing the lights on my shifter in a 04+
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  7. #7 Re: Steering Wheel Lights Out
    Wichita
    ooh, you hafta take the entire center console out for that right?
  8. #8 Re: Steering Wheel Lights Out
    Aug 2008
    Fayetteville, NC
    lol you guessed it...but you need a special tool down under the console to finally release it...when I was running my hot wire from my battery to the trunk under the carpet, I had to cut a small hole to run it under the carpet cause I couldnt get the whole center out...but you can never tell unless you took the side plastic off
    I been wanting to change my gear LED's but there's a certain tool you need...unless there's a way to release that particular part...
  9. #9 Re: Steering Wheel Lights Out
    Wichita
    don't know how to do that on the newer models. Ive had to do it on mine to put in new carpet. Total pain in the ass it was = /
  10. #10 Re: Steering Wheel Lights Out
    Aug 2008
    Fayetteville, NC
    yeah, i have no idea what kind of tool I need for that center console, but I tried with a flat-head, nothing....some how it releases it...but If i could ever get it ou, I could replace my LED's....until then, its Black-out shifter!!! good thing my DIC tells me what gear i'm in lol
  11. #11 Re: Steering Wheel Lights Out
    Wichita
    uhm not sure on that model but there could be bolts under the center console holding it down
  12. #12 Re: Steering Wheel Lights Out
    Aug 2008
    Fayetteville, NC
    yeah once u take out the bolts inside the console, there's this metal plate thing with a square hole...its complicated...
  13. #13 Re: Steering Wheel Lights Out
    Wichita
    bolts under the hole?
  14. #14 Re: Steering Wheel Lights Out
    Aug 2008
    Fayetteville, NC
    yeah I think sooo but somehow that metal plate has something to do with it...
  15. #15 Re: Steering Wheel Lights Out
    Wichita
    Hmm w/o looking @ it I have no idea. Cut off the plate??
  16. #16 Re: Steering Wheel Lights Out
    Aug 2008
    Fayetteville, NC
    its been a while, that could be possible though lol...I wish I was at home, I could get you some pics...I wanted to go "all blue" with the inside LED's anyways
  1. Steering Wheel Swap
    By pski920 in forum Visual/Body Modifications
    Last Post: 05-31-2009, 03:48 PM
  2. Steering wheel problem...
    By TMOTA503 in forum General Tech Discussion
    Last Post: 09-09-2008, 07:02 PM
  3. pulling steering wheel
    By quiksilvergt in forum Brakes/Suspension/Chassis
    Last Post: 09-03-2008, 11:20 AM
  4. a little resistance with steering wheel
    By johnnyj773 in forum General Tech Discussion
    Last Post: 05-10-2008, 02:28 PM
  5. Steering Wheel Removal
    By StreetChariot in forum General Tech Discussion
    Last Post: 04-07-2008, 04:46 PM
