Thread: Subbox Frame completed.
Results 1 to 20 of 26
Threaded View
  1. #9 Re: Subbox Frame completed.
    GTP Level Member dstout's Avatar
    ky
    I kinda like the fishmans myself, the first set looks....well kinda blah and not very strong. The spiders are cool.
    You could cut a ring from plywood to fit around the speaker if the grills need to mount to wood and not the speaker itself. Just build up the plywood untill there is enough clearance between the sub and grill. 3/4" plywood might be the right size. Then cover the plywood with the same cloth or spray paint.
  1. 06 gp frame flex??
    By reallyfast1 in forum 04+ Specifics
    Last Post: 09-12-2009, 09:18 PM
  2. what frame
    By TheGreatSamG in forum General Tech Discussion
    Last Post: 03-10-2009, 12:09 PM
  3. Pics from My recently completed Top Swap!!(no 56K!!)
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-14-2009, 07:12 PM
  4. sub frame
    By YoungGTP in forum Brakes/Suspension/Chassis
    Last Post: 10-22-2008, 02:48 PM
  5. Differential COMPLETED!!
    By JCGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-12-2008, 10:56 PM
