Nope that would not be the problem. If your battery is draining, the it is more than likely the alt or the battery, possibly the connections to the connections to the battery. Unless you are running your HU when the engine is off, then yes it will drain your battery no doubt, but not while the car is running, the battery is being charged by the alt while its running, so drain there would not be the problem.
