Thread: doubel din conversion
Results 1 to 13 of 13
  1. #1 doubel din conversion
    Feb 2008
    I have a 01 grand prix gt 3.8 with a aftermarket system i was wondering if it would be possible to remove the headunit and convert that into a double din space for a gps receiver.
  2. #2 Re: doubel din conversion
    TDCRacing
    Guest
    It's already a double din. So you should be able to stick any double din unit in there.
  3. #3 Re: doubel din conversion
    Ohio
    I thought the 97-03 was only a 1&1/2 din?
    00 GTP demodded and forsale
  4. #4 Re: doubel din conversion
    TDCRacing
    Guest
    Quote Originally Posted by speedemongtp View Post
    I never knew there was such a thing.
    Either way a little custome work you can make anything happen.
  5. #5 Re: doubel din conversion
    Ohio
    idk for somereason i remember reading it somewhere could be wrong idk. but yea what you said a little custom work an anything can happen
  6. #6 Re: doubel din conversion
    SE Level Member davidl25's Avatar
    Apr 2009
    evansville in.
    Not really it is really a 1&1/2. I have already put a couple in the gp's. You have to trim the dash under the center vents and below the radio opening. About 1/4 inch on both. I just got finished with a pioneer double din navi in my friends gp. It looks sweet I will get pics up asap.
    99 GP (SE) GT Clone, KYB AGX struts + SSC springs, GMPP sway bars, GMPP trailing arms, OTTO strut tower brace,Big 3 mod, Stage 2 voltage booster, alt rewire, 180 t stat, HID conversion, D/S rotos and ceramic pads,cold air intake, and an insane car audio setup 150+ db.
  7. #7 Re: doubel din conversion
    Ohio
    thats what i thought. thanks for clarifying david.
  8. #8 Re: doubel din conversion
    Apr 2009
    evansville in.
    no problem. I did car audio for almost ten years. Ive had to put a lot of double dins were they dont be long. Every body loves them.
  9. #9 Re: doubel din conversion
    Ohio
    haha understandable. ive been doin installs for about 4 years now for friends and family but dont do too much w/ that kinda stuff makin if fit where it shouldnt yet
  10. #10 Re: doubel din conversion
    Dec 2008
    Lawndale, CA
    I posted some links in this thread.
    http://www.grandprixforums.net/f41/d...tml#post182884
  11. #11 Re: doubel din conversion
    Apr 2009
    evansville in.
    That looks sweet man.
  12. #12 Re: doubel din conversion
    Oct 2008
    Northern Illinois
    Looks good, if I did this should I pick up the stock NAV from an 04-08 or would I be better off with an aftermarket?
  13. #13 Re: doubel din conversion
    Ohio
    Looks good man. nice job
  1. Tap shift conversion
    By merciero in forum 04+ Specifics
    Last Post: 04-18-2009, 08:20 PM
  2. cavi conversion?
    By riceburner in forum General Tech Discussion
    Last Post: 04-12-2009, 03:22 PM
  3. HID Conversion Kits
    By DJFirestorm07 in forum Visual/Body Modifications
    Last Post: 11-25-2008, 12:40 PM
  4. what do you need for an 8 rib pulley conversion?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2008, 01:56 PM
  5. gt conversion to s/c
    By 59chevy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2008, 10:52 PM
