yes iroccamarofan is right but the only thing is if you get a line out converter then, you will be able to set the sub to only receive the lower frequencies
Ok so now you still need to amplify the signal for the subwoofer. The output is not going to be enough to properly drive the woofer. You are still better off saving your pennies for a proper car audo amp and woofer and do it right the first time. You will have less problems, it will be done correctly, and sound much better!![]()
