Thread: Noise with 4 channel amp.
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #1 Re: Noise with 4 channel amp.
    Donating Users jacobmh27's Avatar
    Naugatuck CT
    I just called Crutchfield and they said they had no idea but I could send it back and they would look at it I think I will try this first and them if it does work I will send it to them when I leave the country again. See if they can fix correctly but for now I will try this.
    http://www.cardomain.com/ride/3059486
    2001 GTP, TransGo shift kit, SSAC Headers, AeroForce Scan, TDC Racing FWI, Overkill PCM, 3.4 Pully,MSD Coil Packs, Moroso Wires, AL104's, 160Tstat
  2. #2 Re: Noise with 4 channel amp.
    Oct 2008
    mascoutah, Il
    try unplugging the connector on the alternator. Not the power wire but the signal clip. Start and run the car. Noise Gone?
    I forget what wears out, but its a cheap fix.
    2002 GTP
    custom HOK paint
  3. #3 Re: Noise with 4 channel amp.
    GT Level Member WhiteGT's Avatar
    May 2008
    Ontario
    I have not got a chance to swap out the decks yet so I am still unsure if that is the issue or not. Geddylee, I have not tried grounding it out like that. Deffinitlly an option if The head unit is the problem. I will also check that signal wire on the alternator as well too.I just have the gains turned way down right now to minimize the noise but this way I can't get the amp tuned the way I would like it either. I'm also supposed to go to the stereo shop thursday night for them to take a look at it as well. Thanks for all the input.
    Josh
  4. #4 Re: Noise with 4 channel amp.
    St. Louis Mo.
    Glad I could help Jacob! Enjoy your new stereo!
    I suffered through the same thing you did for about 6 months before I saw this trick! Like you I was simply floored by how well it worked! It is just a shame that Pioneer could not do a better job of grounding their RCA jacks.
    James Shafer
    St. Louis MO
  5. #5 Re: Noise with 4 channel amp.
    Naugatuck CT
    Oh I am now this thing sounds like nothing I have ever had before. My wife thanks you too. I just only wish that you could change her taste in music hahaha
  6. #6 Re: Noise with 4 channel amp.
    St. Louis Mo.
    Quote Originally Posted by jacobmh27 View Post
    LOL what? She likes "Barely Man Enough?" ie Barry Manelow*
    James Shafer
    St. Louis MO
  7. #7 Re: Noise with 4 channel amp.
    Naugatuck CT
    she is a R&B girl and I am Rock and Metal haha nice about the Man enough though. Driving the car with no Whinney noise is so nice
  8. #8 Re: Noise with 4 channel amp.
    SE Level Member KingOfTheSouth's Avatar
    Nov 2008
    homestead
    i have the same issue with my doubledin its a pioneer so i went to the shop and they installed something called noise suppresor something like that they are little boxis that go on every speaker around the car and eliminates that noice and they did the same thing that the pioneer in the picture has but they did that to my amps RCA plugins and worked fine so i guess you can try that
  1. channel plate input shaft sleeve scored.. HELP!
    By carfreak967 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-08-2009, 10:43 PM
  2. mono amp vs two channel
    By comongoose in forum Audio, Security & Visual Electronics
    Last Post: 03-20-2009, 12:04 PM
  3. any interest in setting up IRC channel?
    By fst in forum Forum Bugs/Suggestions
    Last Post: 12-13-2008, 02:56 PM
  4. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  5. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
