try this
Quote Originally Posted by Warhellride View Post
There are two plastic tabs on the headlight bracket. It's easy to miss one of them when reinstalling the headlights, which will cause the headlight to be very wobbly and aimed wrong. I'd take the headlight out and make sure both tabs are inserted first.
If that's not the problem, there are two E8 Torx screws used to adjust the headlight. They're located on top of the plastic bracket. The inboard one is for side to side adjustments, and the outboard one (on the corner near the turn signal) is for up/down adjustments.
