Thread: Are Optima Batteries any good?
Results 1 to 16 of 16
  1. #1 Are Optima Batteries any good?
    Moore, Oklahoma
    I just bought an Optima Red Top battery Sunday after my 4 year old Diralast Gold failed on me with a bad cell.
    Its the Red Top "Starting" battery i got which is PN 34/78. Its got 1000 CA, 880 CCA, 100 RC.
    I heard these batteries are pretty damn good, I hope it was worth the money. It was about $40 more than my usual Duralast batteries. I don't have any stereo strain happening because I have all stock equipment. I do have 2 sets of HIDs, and IC pump, DO controller, Radar detector, aftermarket gauges, Wideband, and an ICCU straining my battery generally at start up. Also at the track, I'll want to run my IC pump + HIGH Speed fans without the battery dying on me. From my research, the Red top should suit my needs perfectly, right?
    Just wondering.....
    Shawn W. Larsen
  2. #2 Re: Are Optima Batteries any good?
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    The RedTops are not much different then any other battery...it is the YellowTops that are solid. I have not heard much good about them recently, and personally have never been let down by the EverStart batteries.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  3. #3 Re: Are Optima Batteries any good?
    Jan 1970
    Maquoketa, Iowa
    My car came with a yellow top, so far I havn't been able to drain it. I went camping a few times and I had the sub on for hours and it started right up, I'm pretty sure I passed out once with the stereo still on and it was still going when the sun came out, the yellow tops are possessed! I think that many devices hooked up on startup would be hard for any battery.
  4. #4 Re: Are Optima Batteries any good?
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    Shawn,
    I have had my red top since 01 and am not looking back.
    Red top is the best for starting and above average electrical load.
    Yellow tops are the bad boys but they are meant to be deep cycled which average person will not do. So red top is perfect.
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  5. #5 Re: Are Optima Batteries any good?
    Moore, Oklahoma
    Quote Originally Posted by Toofastgs View Post
    Shawn,
    Good to hear McPeek! I remember you had one, in fact I tried calling you with no luck (I have a wrong number I think).
    I take it you probably have the same exact battery I have now? Hoping I can get the use you have out of yours...
    Shawn W. Larsen
  6. #6 Re: Are Optima Batteries any good?
    Dec 2008
    Lawndale, CA
    I have had my car for 10 years. I had the stock battery for two years before the terminal leaked. I bought a yellow top and that lasted 7 years. I replaced it with a red top that I have had for almost a year. So far so good with optima.
  7. #7 Re: Are Optima Batteries any good?
    St. Louis Mo.
    This might help Shawn
    I checked Consumer Reports Online and they tested batteries with the top and side post connectors and here were their findings....
    1. Sears Platinum Battery (I bought this one) rated in with a score of 91, but it also cost $180 bucks.
    2. Optima Red Top Battery rated second with a score of 76 and it costs $150 bucks (thats actually priced a lot higher than I have seen at Costco, they had them for a little over $100 bucks)
    5. Napa Select 84 34/78 rated at 5th spot with a score of 67 and was picked as a Consumer Reports "best buy" selection costing $82
    The Everstart batteries from Walmart rated in the low 60's and their price averaged around $75 bucks.
    I went with the best cause you want to have a good battery regardless of whatever you do. The Napa is a good middle ground battery that should provide ample power. I can say after owning 2 Everstart batteries from Walmart in 3 years, they are not worth their weight in salt. I choose the Sears Platinum cause it was the best in all categories. Sure it cost weight more, but with the extra year warranty and the extra year of a prorated warranty I felt it worth the extra change.
    James Shafer
    St. Louis MO
  8. #8 Re: Are Optima Batteries any good?
    Waynesboro, PA
    Quote Originally Posted by GeddyLee View Post
    I checked Consumer Reports Online...
    Those folks really cannot be trusted.
  9. #9 Re: Are Optima Batteries any good?
    Donating Users lazie82's Avatar
    SOUTH TEXAS
    Yellow tops are good if you have a big stereo system.
    ====> OVERKILL PCM, 3.4 PULLEY, XS HEADERS, 3" DOWN PIPE, CAT & U-BEND DELETE, 160*DRILLED, K&N COLDAIR, MSD COILS & WIRES, NGK PLUGS, AND ~~AIR~RIDE~~
  10. #10 Re: Are Optima Batteries any good?
    memphis
    I had a yellow top in my stratus..i had a nice 2 amp set up & never had a problem with tha lights dimming or anything..
  11. #11 Re: Are Optima Batteries any good?
    GTX Level Member WhiteDevil's Avatar
    Aug 2008
    60118 NE Illinois
    I have never owned one however The ones that do get returned to my store are yellow and blue tops, we dont sell the weaker red ones due to the nature of our business.
    It sounds like the red top will work for what you got. I had the same spec battery you got but in delco form and its still fully charged and 14 years old.
  12. #12 Re: Are Optima Batteries any good?
    GTP Level Member dstout's Avatar
    ky
    Why do they get returned?
  13. #13 Re: Are Optima Batteries any good?
    Aug 2008
    Long Island, New York
    you will be fine with the red top. its still got the spiracell setup... its just not the BEST one. still a great battery
  14. #14 Re: Are Optima Batteries any good?
    Aug 2008
    60118 NE Illinois
    I just got back 5 optima yellow tops yesterday, all 5 of them had cracks by the terminals, never installed. I wouldnt waste the money, you can get something alot better cheaper, optima technology is just that, their technology.
  15. #15 Re: Are Optima Batteries any good?
    Tulsa, Ok
    Red top = Starter
    Yellow = Extreme heavy load (deep cycle)
    Blue = marine use
    There saying will outlast your car. Has outlasted my 97GT, my first 2k and my 2nd 2k and is now in the regal. Starts every time. Well that one time i ran my high current stereo for 3+hrs and not starting the cat to keep it charged :-/
    PS. Shaw ya my number changed. Got rid of the cell. Ill send you a pm with my home number. Also to ask your addy so zach can send you a wedding invitation
    98' GS - Sold
  1. Good bye :(
    By 98GPGT in forum Off Topic Discussion
    Last Post: 12-21-2008, 01:44 AM
  2. Good Buy ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 09-25-2008, 11:58 AM
  3. So this looks like a good little add on
    Last Post: 04-11-2008, 12:00 AM
  4. Good day!
    By bat119 in forum Introductions/Noob Questions
    Last Post: 03-06-2008, 07:36 PM
