Thread: What is the best way to mount a sub and amp in the trunk?
Results 1 to 5 of 5
  1. #1 Re: What is the best way to mount a sub and amp in the trunk?
    SE Level Member prettyprix's Avatar
    Oct 2008
    Columbus, Ohio
    That's a good idea. I was thinking about using a board, but i really didn't want to carpet it and everything. I didn't even think about putting it under the carpet. Would that move too much tho? say at the track after i put a supercharger on it? lol
  2. #2 Re: What is the best way to mount a sub and amp in the trunk?
    St. Louis Mo.
    I basically did the same thing JCG mentioned above. I cut out several MDF boards to put on the back side of the carpet to anchor the amps to. I did however drill two screws into sheet metal to hold the MDF in place so the amps would not wobble. They are above the splash guard so I am not worried about rust or anything.
    I have a new sub box, a pair dual 10" Power Akoustics inplace of the one 12" sub in the pictures below. But you can see how clean the install came out.
    Before being mounted to the MDF board behind the carpet.
    After placement was made and set.
    James Shafer
    St. Louis MO
  3. #3 Re: What is the best way to mount a sub and amp in the trunk?
    Topeka, KS
    Here's how I Mounted my setup.
  1. Trunk ?
    By b00stinGTX in forum Visual/Body Modifications
    Last Post: 02-26-2009, 02:34 AM
  2. trunk weight
    Last Post: 11-28-2008, 01:47 AM
  3. trunk problem please help
    By bigjay110 in forum General Tech Discussion
    Last Post: 08-19-2008, 03:04 PM
  4. trunk problems
    Last Post: 08-19-2008, 01:03 PM
  5. 4T65-HD in the trunk?
    By Iron Indian in forum Off Topic Discussion
    Last Post: 02-04-2008, 04:03 PM
