Thread: california profile 1000M amp...HELP?
Results 1 to 8 of 8
  1. #1 california profile 1000M amp...HELP?
    SE Level Member bb52190's Avatar
    Jul 2008
    ky
    I have a cali profile 1000M amp hooked up in my grand prix and just the other day it seemed to start messing up. The amp will power the subs up to a certain volume level, which is only volume level 3 and it can go up to volume level 40, and then the amp cuts off. Then a few seconds later it will cut back on then rite back off. The led light blinks and the subs dont get any power after that. If you can help me figure it out then write me bak please. thanks
  2. #2 Re: california profile 1000M amp...HELP?
    TDCRacing
    Guest
    Is the amp going into protect mode?
  3. #3 Re: california profile 1000M amp...HELP?
    Oklahoma
    What the *$%%???!!!! Does anyone at all read the friggin' forum descriptions at the top of the page. We have an audio section and this ended up in How To Write ups? Some one explain this crap to me......
  4. #4 Re: california profile 1000M amp...HELP?
    Oklahoma
    Moved!!!!
  5. #5 Re: california profile 1000M amp...HELP?
    Jul 2008
    ky
    How would I know if it was going into protect mode? And is there anyway to fix it if it is in protect mode?
  6. #6 Re: california profile 1000M amp...HELP?
    Nov 2008
    Cedar Rapids, IA
    Well since it is a profile the protection light would be lit.
  7. #7 Re: california profile 1000M amp...HELP?
    SE Level Member abuckley1290's Avatar
    Jul 2008
    Make sure you have a solid ground and the ground wire is the same gauge as the power wire. I had this problem before and thought it was the amp, but i got a new ground wire and got it down to bare metal and it worked perfect
  8. #8 Re: california profile 1000M amp...HELP?
    GT Level Member JCG's-GTP's Avatar
    Feb 2008
    Nashville
    Sounds like protect to me. Sounds like your running too low of an impediance for the amp. for example: if its stable 2ohm mono and your running it 1ohm mono. Now if has always worked and just started messing up it could be a number of things. But i would check impediance first
    OverKill PCM, PRJ 10.4 Wires, AutoLite 605, WizAir CAI, ZZP Plog, 2.5" Down Pipe, 3.5 Pulley, 180* Tstat, Borla Exhaust MECA SQ JL AUDIO 500/1, 300/4, 2-10W3V2, XR650-CSI, Kenwood DDX-6019 , Alpine amp and JL TR400CX center channel , 300 lbs of Dynamat.
  1. california
    By bayareagtp in forum West
    Last Post: 03-08-2016, 10:08 PM
  2. So who here thinks Trannyman should change his profile?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 02-26-2008, 09:39 PM
