Moved!!!!
Moved!!!!
How would I know if it was going into protect mode? And is there anyway to fix it if it is in protect mode?
Well since it is a profile the protection light would be lit.
Make sure you have a solid ground and the ground wire is the same gauge as the power wire. I had this problem before and thought it was the amp, but i got a new ground wire and got it down to bare metal and it worked perfect
Sounds like protect to me. Sounds like your running too low of an impediance for the amp. for example: if its stable 2ohm mono and your running it 1ohm mono. Now if has always worked and just started messing up it could be a number of things. But i would check impediance first
