Thread: Can you shut your lights off?
Results 1 to 20 of 25
  1. #1 Can you shut your lights off?
    SE Level Member isucyclones3's Avatar
    Jan 2009
    mason city
    Anyway to shut your daytime running light off or shut your lights off at night?
  2. #2 Re: Can you shut your lights off?
    GT Level Member nutcase's Avatar
    Washington State
    i tryed to engage the ebrake just a tad...that didnt work. can't remember who told me that did it...it didn't.
    My car doesn't leak oil,
    It marks it's territory.
  3. #3 Re: Can you shut your lights off?
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    On a 2008 you can. What year is yours
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  4. #4 Re: Can you shut your lights off?
    GTX Level Member kingd44's Avatar
    Feb 2008
    newyork
    there is a thread on here that will tell u how to shut them off.......i have a99 and i just pulled a fuse from under the dash...was a long time ago so i forget where it was exactly but if u search u will find out how
    180 t-stat, wizaired cai, s&s headers, 3inch cat back exhaust,jpg plug wires, auto lite plugs, 3.4 pulley, and ovk pcm......rockers to come............next summer might go intercooled
  5. #5 Re: Can you shut your lights off?
    May 2008
    Winnipeg, MB
    on a 2007 you can't, I've asked and searched for a way to do it and not been able to
    2007 Pontiac Grand Prix
  6. #6 Re: Can you shut your lights off?
    Feb 2008
    newyork
    hes got a 2000
  7. #7 Re: Can you shut your lights off?
    Washington State
    i've got a 98
  8. #8 Re: Can you shut your lights off?
    Feb 2008
    newyork
    i ment the dude who made this thread lol
  9. #9 Re: Can you shut your lights off?
    Washington State
    i wasent replyin to you :P
  10. #10 Re: Can you shut your lights off?
    SE Level Member blbstud1424's Avatar
    Jan 2009
    Fort Wayne
    u have to have the key off then engage your e brake one click and then turn your key on and u will have no lights!
  11. #11 Re: Can you shut your lights off?
    GTP Level Member 99gpse's Avatar
    Dec 2008
    Freeman, SD.
    ^^ that doesn't work on all cars....
    the DRL's on my 99 haven't worked in a couple months.. just the auto lights
    '90 Acura Legend LS V6 2.7 5MT ^
    '87 Acura Legend V6 2.5 5MT
    '94 Saab 900 SE V6 2.5 4AT
  12. #12 Re: Can you shut your lights off?
    Jersey
    just pull the fuse, its like a whole new world.
    16' wrx sti- stock
  13. #13 Re: Can you shut your lights off?
    Nov 2008
    Cedar Rapids, IA
    I think there is a way to turn off your auto lights. Now don't quote me but it SHOULD work. I have no idea what it is though :-/ If anyone has a 99-2002 silverado check the owners manual. There is a sequence with the headlight switch and the ignition key that will disable the auto on headlights. Now this will probably only work on 99 and up Gp's but it should work since they are essentially the same systems. Somebody do some diggin.
    p.s. to the o.p. I'm totally from Mason City Ia too.. word
  14. #14 Re: Can you shut your lights off?
    Jersey
    Quote Originally Posted by crywolf View Post
    No, only pulling the fuse works.
    16' wrx sti- stock
  15. #15 Re: Can you shut your lights off?
    Hoffman/Schaumburg, IL
    Quote Originally Posted by nutcase View Post
    It needs to be before you turn the key for this trick to work
  16. #16 Re: Can you shut your lights off?
    Nov 2008
    Cedar Rapids, IA
    Quote Originally Posted by 99prixgt View Post
    Ok. No. If a car is equipped with auto headlights by law there HAS to be a way to override the system besides just pulling a fuse. Didn't you wonder why there was an off position on the switch? Edit: Now that I've had 10 min. to brood I'm rather upset with your statement. How could you possibly state that only pulling the fuse would work? You can pull the fuse, unplug the sensor (may throw a code or disable lights altogether), click the e-brake, try my override, or diode the sensor as well! All of these will effectively shut down the auto headlight system. Let's not just assume that because your method is widely used that it is the only method. Ignorance is never appreciated.
  17. #17 Re: Can you shut your lights off?
    Washington State
    i tryed that and i just dont feel comfy driving around with my ebrake light on!
  18. #18 Re: Can you shut your lights off?
    SE Level Member Farmboy87's Avatar
    Jan 2009
    try this site http://lightsout.org/ I believe this is were I got the info to do it on my 01 Gt
  19. #19 Re: Can you shut your lights off?
    Jan 2009
    mason city
    The ebrake trick worked in my 2000 gp. Will it do anything to the brake even though its only one click?
  20. #20 Re: Can you shut your lights off?
    Jan 2009
    You should also just be able to pull the fuse out in the fuse panel on the 2000 gp's but, on the 2001 and newer doing that cuases a relay in the drl module to keep makeing an annoying clicking sound. So you have to remove some wires from the drl module the link I have posted above is what I think I used and it worked fine. I also bypassed the auto dimming sensor with a relay between the two wires I believe I used a 3 ohm resistor to do this.
  1. Go baby Go... Car wont shut off!!
    By a2morale in forum General Tech Discussion
    Last Post: 01-15-2009, 06:17 PM
  2. Car wont shut off!
    By BrokenRhythm in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-04-2009, 05:39 PM
  3. PK III and Remote start...auto shut down grrr
    By mongo in forum General Tech Discussion
    Last Post: 08-07-2008, 06:37 PM
  4. Rear door will not shut *Solved*
    By Fish in forum Visual/Body Modifications
    Last Post: 12-25-2007, 02:53 AM
