Thread: Door panel
Results 1 to 6 of 6
  1. #1 Door panel
    Feb 2009
    chicago
    IS THERE A TRICK TO TAKEN OUT THE DOOR PANEL. I WANT TO REPLACE THE SPEAKERS AND IT SHOWS ME TO USE A 10MM SOCKET. I TRIED BUT THE SOCKET DOES NOT GO ALL THE WAY IN. HOW HAS EVERYBODY ELSE DONE THIS.
  2. #2 Re: Door panel
    St. Louis Mo.
    You have to use a Torx bit to remove the two bolts underneath the door handle. There are two caps covering the spots where the torx bolts are. You remove those first, then gently pull from the lower rear corner (towards the trunk of the car) and you will hear the plastic peg holders pop out one by one as you move up the side of the panel and then once you have unpopped those you can slide your hand along the bottom of the door and pop those out until you have gotten all them popped out. Then you pop out the controls in the door and then you can fully remove the panel.
    Not hard actually, just getting the torx bolts back in is a buggar. I recommend magnatizing the torx bit or use something tacky that will help the torx bolt to stay on the bit when screwing them back in.
    James Shafer
    St. Louis MO
  3. #3 Re: Door panel
    Feb 2009
    chicago
    just want to say thanks again.
  4. #4 Re: Door panel
    SE Level Member Hayden's Avatar
    Aug 2008
    Michigan
    Hmmm. I guess it depends on what year the car is. I have no torx bolts. Just the 2 10mm bolts in the cover on the handle and a few screws along the bottom.
    2008 Grand Prix + Kenwood KVT815DVD, Kicker SXRC Controller, Kicker SX 1250.1, Kicker (2) 12" L7's, Kicker SX 900.4, Kicker RS65.2 Components in front. Infinity Refs 9623i 6X9's in rear
  5. #5 Re: Door panel
    Feb 2009
    chicago
    It's a 2006 and it has two bolts. but the 10mm socket does not fit all the way in. What else can i use to take them out.
  6. #6 Re: Door panel
    Jan 2009
    Michigan
    you have to get a "thin walled socket" to get in there. I had an old cheap socket set that didn't have an actual socket wrench, just a screwdriver handle with a 1/4" socket connection at the end and a selection of metric sockets. Those were thin enough to squeeze down in those holes. I tried 4 different sockets, and only that one was able to get in there and I had to push it a little.
    Generally the higher quality socket sets are have thicker walls on them...which normally is good of course. Makes them stronger and they tend to last longer. Sometimes, these cheapies come in handy though too.
  1. Question to those who have or will have their front int. door panel off
    By mntnbiker in forum Audio, Security & Visual Electronics
    Last Post: 06-30-2009, 09:13 AM
  2. How Do I Remove the Left Quarter Panel?
    By y1a3o in forum Off Topic Discussion
    Last Post: 05-12-2008, 01:24 PM
