unrelated problems but I thought id just mention everything a once. so starting out I changed my fuel sending unit about 5 months ago and the gauge started acting funny a month later (saying I have 3/4 tank when I only have about 2 or 3 gallons left) then a few weeks later just completely stopped working (says full tank when the car is started then moments later says tank is completely empty for the rest of the drive no matter how much fuel I actually have). I checked the connections at the cannister and everything seemed fine and checked the connector with the key in the on position and got 4 volts? is it supposed to be this low if not what do I look for?l
Did you use the old fuel level sensor? If so, it may have given up after the move.
