Thread: Fuel gauge and temperature gauge issues
Results 1 to 6 of 6
Smalltownboy Fuel gauge and temperature... 04-28-2019, 08:48 AM
Fivefingerdeathpunch Re: Fuel gauge and... 04-28-2019, 07:57 PM
Bronco Boy Re: Fuel gauge and... 04-29-2019, 12:13 PM
FordMan77 Re: Fuel gauge and... 04-29-2019, 09:43 PM
97gtp01gt99gt Re: Fuel gauge and... 12-30-2019, 11:01 AM
Hurricane87 Re: Fuel gauge and... 01-01-2020, 09:20 PM
  1. #1 Fuel gauge and temperature gauge issues
    Apr 2019
    Charlotte
    Sorry if I’m posting in the wrong spot but I have racked my brain in a number of different fashions to figure out my issue. I have a 2002 Pontiac Grand Prix GTP, and have previously owned a 99’SE. and if I remember correctly had the same issue with that car. The car in question is newly acquired and I have two nit picky issues that I cannot solve #1 the temperature gauge is not reading and when I plug an obd2 sensor into the computer monitoring port it is reading that it is getting a signal from the temperature sending unit but it is not showing up on the dash gauge, bad ground maybe? The needle never moves. #2 the fuel gauge is not working correctly. While sitting still with the ignition in the start/run position the fuel gauge will read the level in the tank, from what I can tell fairly accurately. But when the motor is cranked the gauge will rise until it is maxed out.
  2. #2 Re: Fuel gauge and temperature gauge issues
    From what I remember the temp sensor sends a signal to the PCM and the cluster. A bad sensor can still send it to the computer but not the cluster. It's a messy drop if you don't suck the coolant out of the lower intake but it's a simple swap.
  3. #3 Re: Fuel gauge and temperature gauge issues
    Jul 2010
    Coquitlam,BC,Canada
    Possible fuel sender issue for the fuel gauge problem.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Fuel gauge and temperature gauge issues
    St. Louis
    Check the wiring to the temp sending unit. It gets baked over years of heat. My 00 GT is doing that now. Had to mess with the wires a bit to get the dash gauge to read.
  5. #5 Re: Fuel gauge and temperature gauge issues
    GT Level Member 97gtp01gt99gt's Avatar
    Sep 2018
    Saint Louis
    Got this issue to with the needles. It reading right tired reinstalling reverse cluster gauge and 04 gp never swap
  6. #6 Re: Fuel gauge and temperature gauge issues
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    Quote Originally Posted by 97gtp01gt99gt View Post
    En ingles, por favor?
  1. Temperature gauge always on red . 260
    By Diegozr1 in forum General Tech Discussion
    Last Post: 10-27-2016, 11:19 PM
  2. SC Modular Pulley - Gauge Pod - Air/Fuel Gauge
    By 02GTPJeff in forum For Sale - Parts
    Last Post: 01-14-2016, 07:08 AM
  3. how to diagnose and repair fuel level gauge issues 2001 grand prix se 3.1
    By onlywinged1 in forum How To Write-Ups/Tech Tips
    Last Post: 03-06-2014, 12:28 AM
  4. Fuel gauge issues
    By spider4 in forum General Tech Discussion
    Last Post: 12-06-2011, 09:52 PM
  5. le gauge cluster fuel gauge dnt work
    By cliffdawg in forum Visual/Body Modifications
    Last Post: 11-21-2011, 08:50 PM
