Heh - I made a funny thread title.
So I just sold my 2000 GT and now I'm driving a 2001 GTP. Both cars have fuel level sender problems where they read lower than real world. So I just got in the habit of running my DIC in "gallons used" mode. That way, when the fuel sender and gage went into false "low fuel" mode - I knew how many gallons I really had left.
On my 2000 GT, the fuel used mode was amazingly accurate. When I would fill up the pump amount and the DIC display amount were always no more than 1/10th of a gallon off from each other.
But on the 2001 GTP, the DIC is always about 1 gallon lower than what I pump back in. Which is a large enough amount that I could possibly get myself in trouble and run out of gas.
I assume that the DIC computer is using some kind of calculation to come up with how much fuel is used - not based off of the faulty sending unit but probably the ECU and injector pulses and miles or something.
Does anyone know how the fuel used is calculated and why it would be off by 1 gallon after about 10 gallons are used?
