Thread: 2001 door speaker dilema
Results 1 to 9 of 9
gallileo60 2001 door speaker dilema 02-20-2018, 01:10 PM
wstefan20 Re: 2001 door speaker dilema 02-20-2018, 01:35 PM
gallileo60 Re: 2001 door speaker dilema 02-20-2018, 01:53 PM
wstefan20 Re: 2001 door speaker dilema 02-20-2018, 02:06 PM
gallileo60 Re: 2001 door speaker dilema 02-20-2018, 02:27 PM
wstefan20 Re: 2001 door speaker dilema 02-20-2018, 03:31 PM
gallileo60 Re: 2001 door speaker dilema 02-20-2018, 03:32 PM
wstefan20 Re: 2001 door speaker dilema 02-20-2018, 03:47 PM
gallileo60 Re: 2001 door speaker dilema 03-02-2018, 04:56 PM
  1. #1 2001 door speaker dilema
    Feb 2018
    texas
    Is there something in the stock wiring that will prevents the front door speakers from working with an amp, versus the speaker outputs on a sony head unit...??? Strangest thing, going thru the amp, and xover i get no sound to the front door speakers, works fie with the head unit....Not an amp problem..I know some cars had grounded wires, or floating wires forget which..Driving me crazy....Thanks..
  2. #2 Re: 2001 door speaker dilema
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    What year? What stock amp do you have? do you have onstar? Are you on stock had unit or aftermarket? What amp are you using and what's your hookup?
  3. #3 Re: 2001 door speaker dilema
    Feb 2018
    texas
    2001 coupe, no onstar, no stock amp....Running a sony 57up driving front and rear speakers, rca's to brutus amp on kicker sub...Works fine like that...When I try to amp the door speakers going thru eq , I get no sound, used 2 different amps, ran continuity test on wires, seems ok...Things got me baffled...
  4. #4 Re: 2001 door speaker dilema
    Aug 2017
    Raytown, MO
    Trying to make sure I understand you. So currently, you're running your speakers off your Sony head unit, non amp, but you're trying to run the speakers out rca to eq then from eq you amp and from amp to speakers? I'm guessing you already have the amp on wire ran? Where is the equipment located? If in the trunk, do you just have wires run from the trunk to the head unit? Where are you tying in for the speakers (location and wire color)?
  5. #5 Re: 2001 door speaker dilema
    Feb 2018
    texas
    Tiying in at head unit to the factory wiring, amp is on swing down between rear seats...rca's down one side, power remote turn on down other side, big 3 done 2 gauge running to back..New cables, new wire......Huge frustration....This aint my first rodeo, but I feel like im doing something stupid here...Both amps, one a crunch, one an older hifonics are 2/3/4 channel amps...One set of preouts on HU going to EQ7 3 preouts off that...Could be I have something on head unit set wrong for full range out......ARGG.....
  6. #6 Re: 2001 door speaker dilema
    Aug 2017
    Raytown, MO
    I'd drop your glove compartment and look for a grey box behind there. It's the Delco amp. You'll need to either run new wires to the doors, or remove it and tie into the wires. I'll try to find the factory pinout. I've done it before.
  7. #7 Re: 2001 door speaker dilema
    Feb 2018
    texas
    Im a dumbass, nothing wrong with wiring, head unit was set to sub out.....All fine now, thanks..
  8. #8 Re: 2001 door speaker dilema
    Aug 2017
    Raytown, MO
    Quote Originally Posted by gallileo60 View Post
    Lol you're fine! Trust me, I've totally been there before. Glad it was something easy!
  9. #9 Re: 2001 door speaker dilema
    Feb 2018
    texas
    Oh my god, i love the 6.5 JL Audio speakers I put in the doors, it was a lot of work, BUT Fu@$ they sound really nice, tweeters are so laid back, and soft......Got them from Cruchfield for half price as they are discontinued........I am so happy....Am looking to seal the doors a bit better, anyone got some suggestions in that direction??? Thanks again guys....
  1. Speaker replacement - 2001 GTP
    By OldFart in forum Audio, Security & Visual Electronics
    Last Post: 05-28-2013, 04:15 PM
  2. Door Speaker help
    By GPGT2004 in forum Audio, Security & Visual Electronics
    Last Post: 06-09-2011, 06:20 PM
  3. door speaker
    By PNIGZ in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2010, 04:07 AM
  4. door locks/BCM/speaker/ door question
    By adamlesandrini in forum Audio, Security & Visual Electronics
    Last Post: 03-17-2009, 05:14 PM
