Thread: Disable Tire Pressure Monitor Alert?
Results 1 to 13 of 13
  1. #1 Disable Tire Pressure Monitor Alert?
    Sep 2017
    Winneconne, WI
    I use aftermarket wheels on my GXP for winter. They have no sending units for tire pressure. Is there a way to disable the alert so I don't have to reset the readout every time I start the engine? Also, the yellow warning light is always lighted in the cluster with the sending units not communicating with the monitoring system.
  2. #2 Re: Disable Tire Pressure Monitor Alert?
    Nope, not that I am aware of.
    No tuner program that I know of can disable this feature.
  3. #3 Re: Disable Tire Pressure Monitor Alert?
    SWPA
    Buy 4 more units and put them in your aftermarket wheels.
  4. #4 Re: Disable Tire Pressure Monitor Alert?
    Sep 2017
    Winneconne, WI
    Yes, at RockAuto---$40 each X 4 = $160 plus installation. Not going to happen.
  5. #5 Re: Disable Tire Pressure Monitor Alert?
    SWPA
    Then your answer is to deal with the light. There isn't another way.
  6. #6 Re: Disable Tire Pressure Monitor Alert?
    Gotta pay to play.
    You could save a couple bucks buying through napa online to get the 10% off, would be around $140-145. Shoot maybe even auto zone has better online discounts once you reach over $100.
  7. #7 Re: Disable Tire Pressure Monitor Alert?
    SWPA
    Advance has $40 off 100 most times.
  8. #8 Re: Disable Tire Pressure Monitor Alert?
    GTP Level Member
    Oct 2014
    Costco installed 1 for me for 35 bucks. Very reasonable.
  9. #9 Re: Disable Tire Pressure Monitor Alert?
    Sep 2017
    Winneconne, WI
    Quote Originally Posted by markpa View Post
    $35 plus the sender or $35 total for parts & labor?
  10. #10 Re: Disable Tire Pressure Monitor Alert?
    GTP Level Member
    Oct 2014
    Whole deal. Probably a year and a half ago.
  11. #11 Re: Disable Tire Pressure Monitor Alert?
    hangover park IL
    to avoid buying new sensors, you can pay labor to remove your current sensors, buy std valve stems, pay a welding shop to build a pressurizable box, put your TPMS sensors inside and pressurize it to 35psi and let it roll around in your trunk
    should only cost about 200-250$ and youll be able to put any tires/rims on it you want afterwards
    ~James~ Psychotic Gearhead
  12. #12 Re: Disable Tire Pressure Monitor Alert?
    SWPA
    I've seen guys build the pressure box out of pvc using nothing but the glue to hold it together.
  13. #13 Re: Disable Tire Pressure Monitor Alert?
    Sep 2017
    Winneconne, WI
    Clever Idea. I could put three of the OEM wheelsrims in the trunk and one in the back seat. Problem solved!!
  1. Disable low oil and oil pressure sensors
    By DoubleBlown in forum PCM Tuning
    Last Post: 02-04-2013, 07:54 AM
  2. tire pressure disable and lots of lifter tick
    By alreadytooken in forum Audio, Security & Visual Electronics
    Last Post: 12-21-2011, 02:22 AM
  3. Check Tire Pressure light on with no low pressure.
    By DanGTP in forum General Tech Discussion
    Last Post: 11-13-2008, 08:43 AM
