It should be "do-able" if it's like the gxp radio though, I can't guarantee your steering wheel controls will work, and you will probably need the corresponding monsoon amp too.
All depends on what you're going for. What year are you talking about too? 97-03 you'll have some major dash cutting and fabrication. Should fit normal for 04+. Main issue is will it communicate with other systems. If you can find a full schematic and pinout of the radio, I should be able to tell you for sure and even make you a harness if it's possible.
