Thread: Can 4x6's fit in the front door instead of 5.25s?
Results 1 to 5 of 5
  1. #1 Can 4x6's fit in the front door instead of 5.25s?
    SE Level Member ELECTRICxWIZARDx's Avatar
    Sep 2017
    SW Oklahoma
    '01 GTP Sedan, [i think] non-bose.
    I've already put my better 6x9s in the rear, but the OE front left is not working, and front right is rattly. Is there any way to make some 4x6's that i already have fit the front doors, without cutting any of the grill/door card?
    If so, can I still wire in the factory tweeters along with them?
    I know its not ideal, but trying to save some cash by reusing.
  2. #2 Re: Can 4x6's fit in the front door instead of 5.25s?
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ELECTRICxWIZARDx View Post
    Not sure on the door panel part, but you would have to re-work the spacer that the speaker mounts to; without it the magnet would hit the glass. And probably widen the speaker hole in the door itself.
    Yes. In the last image above, you can see how I just joined the factory tweeter wires to my connections for my new speakers.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Can 4x6's fit in the front door instead of 5.25s?
    Sep 2017
    SW Oklahoma
    Awesome, thanks. So just wire in parallel for the tweeters.
    Looks like there might be enough room to trim the spacer a bit to fit an oval. Maybe try a thin [1/4" or so] piece of wood as a spacer if needed.
    Mainly just wondering if it's been done, before i go pop four door panels off.
  4. #4 Re: Can 4x6's fit in the front door instead of 5.25s?
    St. Louis
    Most people just go with 6 1/2" door speakers when they upgrade. Not sure I've ever seen an oval speaker installed in a door.
  5. #5 Re: Can 4x6's fit in the front door instead of 5.25s?
    Sep 2017
    SW Oklahoma
    It was the OE size for front door in my old Malibu.
  1. Front Door lock
    By mtnman in forum General Grand Prix Discussion
    Last Post: 12-15-2013, 10:06 PM
  2. Front Door speakers
    By Thompsju in forum Audio, Security & Visual Electronics
    Last Post: 10-23-2013, 11:39 PM
  3. 6.5 components in front door
    By blakgtp in forum Audio, Security & Visual Electronics
    Last Post: 10-09-2011, 06:28 PM
