Thread: Use monsoon amp wiring for new amp?
Results 1 to 20 of 28
  1. #1 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Is there any way I can run this without drilling? Thanks for your help
  2. #2 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Could I run it through boot beside door
  3. #3 Re: Use monsoon amp wiring for new amp?
    Oct 2011
    Toledo, OH
    Remove the kick panel under the glove box, it's three plastic push pins. Then pull back the passenger foot carpet. There is a large square grommet around a wire harness you can remove to run a thick wire, or to the left of that is the round grommet for the cruise control cable.
    Use a razor to notch out the square grommet to accompany the wire if it's too big, it's designed to be taken out and put back in. Or just use a stiff wire to poke through the small grommet but be careful not to accidentally push out the cruise control grommet because it's a ***** to get back in.
  4. #4 Re: Use monsoon amp wiring for new amp?
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    Quote Originally Posted by industrialfish View Post
    This is exactly how I did it. Super easy. Just remember to secure the wire in he engine bay since your headers are right there on the other side! I forgot I hadn't done this and nearly burned down my car! Course that's just me being dull...
  5. #5 Re: Use monsoon amp wiring for new amp?
    Aug 2017
    Winnipeg
    Thanks.you have been very helpful.amp wire went in great. Last question, is it easy to run new speaker wire to both front doors? I know where to run it after but just the getting it from the door and into the car seems hard!
  1. monsoon rear speaker wiring question...
    By ddw350 in forum Audio, Security & Visual Electronics
    Last Post: 01-19-2014, 08:39 PM
  2. 04-08 Monsoon Wiring Diagram?
    By madpat in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2011, 12:34 AM
  3. questions about the monsoon wiring..
    By blowfishRus6 in forum Audio, Security & Visual Electronics
    Last Post: 11-17-2010, 06:42 PM
  4. Monsoon wiring diagram?
    By GiAnT4LYFE in forum Audio, Security & Visual Electronics
    Last Post: 04-30-2009, 03:34 PM
  5. wiring diagram for 05 non monsoon
    By 05grndprix in forum Audio, Security & Visual Electronics
    Last Post: 10-07-2008, 02:56 AM
