Thread: RAP Problem?
Results 1 to 5 of 5
  1. #1 RAP Problem?
    May 2017
    Long Island
    I have a 2000 GTP coupe and have recently repaired the wiring harness between the driver door and the car (I bought the car with the harness cut) Now, the radio is supposed to lose all power when the key is removed and the driver/passenger door is opened. If the door is not opened, it will continue to play for 8-12 minutes with the key removed. On my car, the radio shuts off when the passenger door is opened, but not when the driver door is opened. However, the driver information center works on both doors. What could the issue be? Thanks.
  2. #2 Re: RAP Problem?
    could be a ignition harness gone bad.
    parking lights tend to stop working right, heater/ac fan could also stay on, or only work on one speed or another.
  3. #3 Re: RAP Problem?
    May 2017
    Long Island
    I thought that it could be the ignition harness, but through further testing I arrived at the conclusion that it was fine. Thanks for the suggestion though
  4. #4 Re: RAP Problem?
    sounds pre existing, no clue how you tested it, but id replace it for the lousy 45 bucks it costs.
  5. #5 Re: RAP Problem?
    May 2017
    Long Island
    Okay thanks for the help
  1. oil problem
    By Snoop dogg in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-16-2013, 01:06 PM
  2. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  3. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  4. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  5. HID problem
    By joshbarker in forum Visual/Body Modifications
    Last Post: 06-09-2009, 01:26 AM
