Thread: Front camera power source
Results 1 to 7 of 7
  1. #1 Front camera power source
    Dec 2008
    Ontario, Canada
    2007 GP base. Putting camera on front windshield. Need power source that goes off/on with key. The cigarette plugs are both hot. Any suggestions that are fairly simple or am I going to have to bit the bullet and run new wiring from fuse box. Suggestions would be appreciated.
  2. #2 Re: Front camera power source
    St. Louis
    Maybe the radio fuse?
  3. #3 Re: Front camera power source
    Aug 2016
    CT/RI Border
    It's better to run a clean wire and its really easy, follow the front of the headliner to your pillar trim, down the pillar and into the fuse box. You can hide the wires easily.
    That said as stated above the radio fuse is the best spot I know of. Maybe the DRL fuse, though I'm not sure if anyone has tried that yet.
    Sent from my ASUS_Z00TD using Tapatalk
  4. #4 Re: Front camera power source
    Jul 2010
    Coquitlam,BC,Canada
    As said, tap the DRL or radio circuit and run the wire up to the camera.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Front camera power source
    Dec 2008
    Ontario, Canada
    Thanks for the help.... look forward to trying it out. Will advise
  6. #6 Re: Front camera power source
    Aug 2016
    CT/RI Border
    I will also say, look into the dash cam you buy. Some can be lined to constant 12 as their "standby" is very batter neutral. One of the perks of a cam like this, is being able to have it wake up if someone backs into you while parked, it will wake up long enough to hopefully see who/what hit you.
  7. #7 Re: Front camera power source
    Dec 2008
    Ontario, Canada
    Gift from my son.... will have to check that out TKS
  1. Wtb front power log
    By Dheffner904 in forum Wanted To Buy - Parts
    Last Post: 03-26-2017, 01:46 PM
  2. Where to wire rear view camera for power?
    By Boomersooner in forum Audio, Security & Visual Electronics
    Last Post: 01-26-2017, 09:08 AM
  3. Front Power Log
    By rottonj in forum Wanted To Buy - Parts
    Last Post: 01-12-2016, 05:32 PM
  4. Aftermarket CD Changer Power Source
    By jerw39 in forum Audio, Security & Visual Electronics
    Last Post: 11-11-2009, 08:30 PM
  5. Source for stock front sway bar?
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 06-26-2009, 07:44 AM
