So I had some stereo gear installed in my car 2 months back. Deck, 4 speakers, amp to power them. I have alternator whine, some distortion and when I put the deck into AUX, I have a LOT of distortion. So, the major issue that I have with this is that, while the amp is a 4ch, it SEEMS to be only operating on 2. I have 2 5 1/4in coax speakers in the doors and 2 6x9's in the stock location, each speaker wired to it's own channel on the amp. If I disconnect the RCA's for side B on the amp, I hear no change in output from my speakers. If I disconnect the L channel RCA on the A side of the amp, I lose both the 5 1/4 and the 6x9 on that side, same thing with the R channel on the A side, I lose both front and rear speaker on that side. When looking at the amp, I see all 4 speakers wired up, 4 for side A, 4 on side B (2 wires per speaker). The amp has an A/AB selector (i'm guessing in case you wanted to bridge side A) and when moving that, it also makes no difference in output. I should also note, when I switch to AUX and plug my iPhone in, the sound is GARBAGE, it's so bad I don't even connect my phone anymore and just listen to the radio.
Prior to me getting an AUX cable, I didn't realize how BAD this sounded, but I can definitely tell how bad the staging is. The problem is, I can't figure out where the problem is: wiring, deck or amp. What kind of things can I do to narrow this down? How can I cure the alternator whine and the distortion I'm getting?
Thanks in advance.
