okay thanks man ill definitly get a new then! and i ended up figuring out they just cut the yellow wire in the radio and used a scrap white to tie it in the fuse box, i undid that and it dosent stay on anymore. and they tied into the sunroof wiring to tap into the fuse box for ther others and i indid hem and it didnt affect anything but i am missing modules for the sunroof smh. but i did want to ask something, there was alot of fuses in different areas where the amps were stronger or weaker than what was called for, but everytime i put the 25amp fuse for the windshield wipers it comes on and stays on even when the switch is off, i was wondering if thats a common problem as well or it could be the switch or motor causing that problem? thanks for all the help figuring this out guys!
