Thread: Where to wire rear view camera for power?
Results 1 to 11 of 11
  1. #1 Where to wire rear view camera for power?
    Dec 2011
    Okc
    I will be installing a rear view camera, and I want it to have power whenever the car is on (not just when in reverse.
    Any suggestions on where to wire it?
  2. #2 Re: Where to wire rear view camera for power?
    Anywhere that has 12v when key on.
    So any of the IGN fuses, radio fuse etc. Just buy an add-a-circuit to make it easy, no splicing wires needed.
  3. #3 Re: Where to wire rear view camera for power?
    Dec 2011
    Okc
    Add a circuit will give you power all the time, even when the key off. I even went ahead and tried it. The camera to the add a circuit is always powered on, even with the car off and the radio off.
  4. #4 Re: Where to wire rear view camera for power?
    Not if it's on a switched 12v source. Shouldn't anyway.
    I power all my aftermarket gauges with add-a-circuits. I always use the radio fuse and IGM fuses, they never stay on when the key is removed.
  5. #5 Re: Where to wire rear view camera for power?
    Dec 2011
    Okc
    Perhaps something was wrong with my stereo fuse. I tried the moonroof one and it worked. Thanks for your help!
  6. #6 Re: Where to wire rear view camera for power?
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    Be sure the camera is rated for continuous on.....many BU cameras are only rated to run <5 mins at a time and will fail quickly of left on continuously. My BU camera had this specific warning in the installation manual, stating that it would fail if wired to constant ignition power.
    2002 GTP Coupe, PSE supercharger ported with 3.4 pulley, Wizaired CAI, ZZP tune, AL 104's, front Plog, 3" DP, u-bend gone, hi-flo cat, W-Body tubular trailing and lateral arms, GMPP sway bars, Vogtland springs, 245/45-18 Michelin Pilot Sport AS/3 on 18x8 wheels, 42mm offset, Dual Aeroforce interceptor gauges on A-pillar pod
  7. #7 Re: Where to wire rear view camera for power?
    Jul 2010
    Coquitlam,BC,Canada
    As mentioned, be carefull with the constant 12v. Here is 12v when ignition on off the "radio" fuse....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Where to wire rear view camera for power?
    i used the wiper fuse for all my extra carp, gauges and amp on power signal.
  9. #9 Re: Where to wire rear view camera for power?
    Dec 2008
    ****'s Creek
    I mean "continuously" when you are driving even if the power is ignition switched 12v
    Sent from my SM-G930V using Tapatalk
  10. #10 Re: Where to wire rear view camera for power?
    SWPA
    Its a back up camera. It only need to be powered on when in reverse. Power it by the reverse light circuit...
  11. #11 Re: Where to wire rear view camera for power?
    SE Level Member smg267's Avatar
    Apr 2016
    killadelphia
    Beat me to the punch.
    99 GTP , 01 Z/28 H/C/I , 05 Hemi Grand Cherokee, 07 Ducati S2r800
  1. Rear View Camera Help
    By Dabman in forum General Tech Discussion
    Last Post: 04-05-2011, 10:41 AM
  2. Rear view camera
    By warren13 in forum Audio, Security & Visual Electronics
    Last Post: 10-21-2010, 12:30 PM
  3. Rear View Mirrow
    By Lucid Violence in forum General Tech Discussion
    Last Post: 09-08-2009, 11:52 AM
  4. Rear View
    By offroadfury6 in forum Audio, Security & Visual Electronics
    Last Post: 09-21-2008, 03:01 PM
