Thread: 98 gtp dash removal
Results 1 to 6 of 6
  1. #1 Re: 98 gtp dash removal
    Replacing Radio
    1. EXTRACT (2) PANEL FASTENERS FROM DRIVER’S (LEFT) SIDE
    UNDERDASH COVER.
    2. EXTRACT (2) 7 MM HEX SCREWS FROM BOTTOM EDGE OF DRIVER’S
    (LEFT) SIDE LOWER DASH PANEL AND CAREFULLY PULL OUT ON THE
    UPPER PANEL TO RELEASE (2) PANEL CLIPS. UNPLUG AND REMOVE THE
    DASH PIECE.
    3. CAREFULLY PULL OUT ON THE COMPLETE DASH/RADIO/INSTRUMENT
    BEZEL, UNSNAP, AND UNPLUG BEFORE REMOVING.
    4. EXTRACT (2) 7 MM SCREWS HOLDING THE FACTORY RADIO, UNPLUG
    CONNECTORS AND ANTENNA TO REMOVE RADIO.
    FRONT DOOR SPEAKER INSTALLATION:
    NOTE: THE FACTORY PROVISION IS FOR A 51/4" SPEAKER MOUNTED IN AN
    ANGLED FACTORY ADAPTER.
    Door Panels ( 5.25 speakers )
    1. EXTRACT (2) COVER CAPS AND (2) T-27 TORX BOLTS FROM THE DOOR
    PULL.
    2. UNSNAP POWER SWITCH PANEL FROM LOWER REAR EDGE FIRST,
    UNPLUG, LIFT AWAY AND REMOVE.
    3. PULL DOOR HANDLE AS IF TO OPEN DOOR AND EXTRACT SCREW FROM
    THAT CAVITY.
    4. UNSNAP MIRROR COVER TRIANGLE AT TOP FRONT EDGE OF DOOR
    PANEL.
    5. USING A PANEL REMOVAL TOOL PRY OUTWARD AROUND THE EDGES OF
    THE DOOR PANEL TO RELEASE POP FASTENERS, LIFT PANEL UP AND
    AWAY TO REMOVE.
    6. EXTRACT (4) SCREWS HOLDING SPEAKER, UNPLUG AND REMOVE
    SPEAKER.
    Rear Deck ( 6 x 9 speakers )
    1. REMOVE REAR SEAT BOTTOM CUSHION AND UPPER CUSHIONS.
    2. REMOVE (3) PANEL FASTENERS FROM FRONT EDGE OF REAR DECK.
    3. LIFT REAR DECK UP IN THE MIDDLE TO RELEASE SIDE EDGES FROM
    AND REMOVE REAR DECK.
    4. EXTRACT (4) SCREWS HOLDING SPEAKER, UNPLUG AND REMOVE
    SPEAKER.
  2. #2 Re: 98 gtp dash removal
    Feb 2009
    Tx
    hey thanks for the help!
    Quote Originally Posted by bsumpter05 View Post
    Replacing Radio
    UNDERDASH COVER.
    DASH PIECE.
    PULL.
    THAT CAVITY.
    PANEL.
    AWAY TO REMOVE.
    SPEAKER.
    SPEAKER.
  1. What do you use on your dash?
    By gdbyrd in forum Detailing Tips and Tricks
    Last Post: 05-02-2009, 01:37 AM
  2. 97-03 Dash Removal
    By cboth686 in forum General Tech Discussion
    Last Post: 12-26-2008, 12:51 AM
  3. Dash Removal?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-21-2008, 05:58 PM
  4. new dash
    By oneswt00gtp in forum Visual/Body Modifications
    Last Post: 04-03-2008, 03:41 PM
  5. Can i get a hi res pic of 04+ dash
    By Rocket468 in forum Off Topic Discussion
    Last Post: 01-31-2008, 11:35 PM
