Thread: HUD brightness
Results 1 to 13 of 13
  1. #1 HUD brightness
    SE Level Member charlie31603's Avatar
    Jul 2008
    Tampa, Florida
    So I have a 98 Daytona GP. The HUD works. But during the day it is hard to see, even on full brightness. At night it is just fine. I have no problems with it dimming by itself or shutting off. It's just the brightness during the day. I know of the solder fix. I have it apart right now and it looks fine. So how bright is it supposed to be during the day?
    1999 Pontiac Montana with a loud whine
  2. #2 Re: HUD brightness
    Dec 2013
    Enfield
    Has the windshield been replaced?
  3. #3 Re: HUD brightness
    Jul 2008
    Tampa, Florida
    Quote Originally Posted by rottonj View Post
    Not that I know of. It was a one owner that was always maintained by the local dealer. Then my last two friends have had it and they would know better.
    I just took it apart and cleaned the crap out of it. I just want to get some ideas before I put it back together. I am so nervous when I pry on these 19 year old plastic pieces. So I would like it done in one shot.
  4. #4 Re: HUD brightness
    GT Level Member mguzzo's Avatar
    Buffalo NY
    reflow the solder anyway. you can't tell just by looking at it. the HUD will brighten up then.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  5. #5 Re: HUD brightness
    Jul 2008
    Tampa, Florida
    Quote Originally Posted by mguzzo View Post
    I'll give it a shot in the morning.
    Sent from my pager using morse code.
  6. #6 Re: HUD brightness
    Jul 2008
    Tampa, Florida
    Re solder it. It seems like it might be a little brighter. But during a sunny day while on lite color road, it is a litte faint. But it is livable for the most part. So I'm happy with it.
  7. #7 Re: HUD brightness
    The HUD isn't always visible if the sun is bright in the right angle on the window. It's a cool system but not quite perfect. Likely what you have now that you reflowed the solder is about as good as it's going to be.
  8. #8 Re: HUD brightness
    Jul 2008
    Tampa, Florida
    Thanks for the conformation of how the HUD is suppose to act. It does work for 90% of the pavement I am on. The light concret on a sunny day is when it fades out some. But I can live with that. Thanks for the help guys.
  9. #9 Re: HUD brightness
    Jun 2016
    Fort Wayne, IN
    I have a 01 grand prix gtp. My HUD is not lighting up. I can tell that it will move up and down if I adjust it, so that part works, it just won't light up. It is frustrating because my radio digital display quit working so I cannot tell what station I am on. Any Ideas? Is there a fuse or is that not an option since I can control that position of it? Any help would be greatly appreciated. Thanks!!
  10. #10 Re: HUD brightness
    GTP Level Member buickman104's Avatar
    NYC
    You need to pull out the hud and reflow the solder on the Photo Cell. I had the exact same problem. Look for instructions in the How to section of the forum.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  11. #11 Re: HUD brightness
    Jun 2016
    Fort Wayne, IN
    In the process of pulling out the HUD, I noticed the spring came off of the mirror. Where exactly does it go and how does it go on? The plastic bit broke off too. I figured I would try to JB weld it or something.
  12. #12 Re: HUD brightness
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    This guide to fix broken spring - http://www.atthetipwebs.com/technolo...ctions/hud.htm
  13. #13 Re: HUD brightness
    Jul 2016
    Any update on the fix? I drilled a new hole in the HUD I had and it worked great. Followed the instructions from the same site provided by SaukRapids. I was told from the person I bought it from that it didn't work because the windshield had been replaced. I noticed there was a tiny little "HUD" in the corner, so I knew it was the right windshield. I looked down into the unit and low and behold it was working just not projecting onto the windshield.
  1. low beams same brightness as DRL's
    By Madness in forum General Tech Discussion
    Last Post: 11-17-2013, 08:37 AM
  2. Different headlight brightness
    By Sandman in forum General Tech Discussion
    Last Post: 10-02-2010, 08:23 PM
  3. headlights are not the same brightness?
    By hockeymaniak88 in forum General Tech Discussion
    Last Post: 09-05-2008, 11:39 PM
