Thread: Axxess ASWC-1 and alpine CDE-147bt help
Results 1 to 15 of 15
  1. #1 Re: Axxess ASWC-1 and alpine CDE-147bt help
    SE Level Member Cruisin38's Avatar
    Sep 2015
    Northern Illinois
    If you're sure the wiring is right and still can't reset it you can try seeing if replacing it with another unit would work. Or going with a different brand altogether
    Or you can try a shop that installs stereos to see if they can get it working. Either an independent shop or some place like best buy, but they might try charging you for needless crap.
  2. #2 Re: Axxess ASWC-1 and alpine CDE-147bt help
    Sep 2016
    Ohio
    The wire harness I used is prewired for the aswc-1 so I can't imagine it's wired incorrectly. I will trace all the wires and double check. I suppose I could order another unit and return it if it does the same thing. Is that your suggestion? The website says its compatible with my stereo. So it should work. What are other people on this site using to retain factory steering wheel controls with an alpine deck? Not sure what other option there is besides the unit I'm using that's wired for it already.
  1. Does anyone have the axxess aswc-1 steering wheel control adapter?
    By tom5170 in forum General Grand Prix Discussion
    Last Post: 03-12-2016, 02:28 AM
  2. Help with ASWC-1 and amp/sub setup?
    By Brammer in forum Audio, Security & Visual Electronics
    Last Post: 09-14-2015, 11:41 AM
  3. Axxess ASWC-1
    By Peirce1970 in forum Audio, Security & Visual Electronics
    Last Post: 06-12-2014, 07:22 AM
  4. Need help with Axxess ASWC please
    By burgundybullet in forum Audio, Security & Visual Electronics
    Last Post: 06-11-2014, 12:12 PM
  5. axxess aswc
    By Mrc728 in forum Audio, Security & Visual Electronics
    Last Post: 12-01-2011, 01:51 PM
