Thread: 9 pin c3 connector help please
Results 1 to 7 of 7
  1. #1 9 pin c3 connector help please
    Nov 2015
    seekonk, MA
    Hello all,
    I need your help with the wiring on my 99 gtp bose radio. i have read the diagram i found in here, my question is how do i bypass it or what do pin 10-12 really do (please dumb it down as much as possible!)
    "Pin 7 - PNK - Radio on signal
    Pins 8 and 9 - Not used
    Pin 10 - LT GRN - Remote playback device right audio signal
    Pin 11 - ORG/BLK - Remote playback device left audio signal
    Pin 12 - LT BLU - Remote playback device common signal
    Pins 13-15 - Not used"
    thank you in advance,
    Bruce
  2. #2 Re: 9 pin c3 connector help please
    10-12 would be like a cd changer in the trunk from teh factory
  3. #3 Re: 9 pin c3 connector help please
    Nov 2015
    seekonk, MA
    ok, so it has nothing to do with the bose system, right?
  4. #4 Re: 9 pin c3 connector help please
    Nov 2015
    seekonk, MA
    i was def wrong. the 9 pin controlled the whole amp... anyone know how/what to do with it?
  5. #5 Re: 9 pin c3 connector help please
    You say you are wiring it.. Give us more info. Did this not come in the car? Are you doing aftermarket.
  6. #6 Re: 9 pin c3 connector help please
    Nov 2015
    seekonk, MA
    I am putting an aftermarket radio in my 99 gtp w/bose. On the back of my factory radio there is the normal 21pin, which isnt the issue. And there is a smaller 9pin that plugs into the bottom middle of the factory radio which controls the amp as far as i can tell... not sure how to find an aftermarket harness for it or cut and splice...
  7. #7 Re: 9 pin c3 connector help please
    Search on Buickman104, I think it's the pink or orange wire that needs power to turn the amp on. Buickman documented it well in a not so long ago post.
  1. what's this connector?
    By 3100sfi in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-03-2011, 07:12 AM
  2. what and where does this connector go?
    By fst in forum General Tech Discussion
    Last Post: 07-13-2011, 03:45 PM
  3. Need help connector
    By lflylow in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 05:34 PM
  4. right connector?
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 05-03-2010, 10:03 PM
